Shifted from UNO to NANO but getting error by using similar code
Sketch uses 8274 bytes (26%) of program storage space. Maximum is 30720 bytes.
Global variables use 585 bytes (28%) of dynamic memory, leaving 1463 bytes for local variables. Maximum is 2048 bytes.
C:\Users\User\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\User\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM5 -b115200 -D -Uflash:w:C:\Users\User\AppData\Local\Temp\arduino_build_609560/sketch_feb08a.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
     System wide configuration file is "C:\Users\User\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
     Using Port                    : COM5
     Using Programmer              : arduino
     Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x62
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x62
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x62
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x62
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x62
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x62
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x62
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x62
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x62
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x62
avrdude done. Thank you.
Problem uploading to board. See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
Try selecting "Nano->atmega328 (old bootloader)"
selected 328 only
... and?
still the error is showing up.
I have selected board as NANO, processor- ATmega328P both new and old, programmer- AVRISP mkll or auduinoISP etc.
Nothing is working.
Changed the cable too.
also, i am not using these pins
especially the 0 (RX) and 1 (TX) digital pins.
I guess your Nano has a serial to USB chip that is not used by Arduino,
and you don't have a driver for that chip installed.
CH340 or similar need a driver that is not supplied by Arduino.
