I'm studying a little bit about electronics and right now I'm experimenting with op-amps.
So far I have read about using an op-amp in the summing non-inverter configuration to shift a signal (or to add an offset) as follows :
In this case, my first question is: How can I select the resistors appropriately?
I made the selection for the resistors based on circuits I saw on google, but I'd like to know how to do it right.
The circuit works fine with a low impedance source, but if I want to vary the input via a potentiometer I'm unbalancing the resistance at the inputs and so, the output won't be as expected as it can be seen in the following simulation:
I guess I could use another OP-AMP to buffer the signal and deliver a low impedance signal, at the moment my input is positive and that will work, but what if I'd like to operate with positive and negative inputs and shift the signals a certain amount (2~2.5V) with no amplification and a positive single supply for the OP-AMP?
So, my second question is: How should I handle those cases?
Hello Brio,
The (+) op amp input is very high in resistance.
Just simplify the voltage sources, adding them up
via algebra. Then the resistors form a voltage
divider which you can calculate easily. R23 just
makes V7 variable. Does that help you?
Herb
Regarding the second question I just wanted to provide an example of what could happen if the resistors aren't well balanced due to a high impedance source... are there any other techniques to shift the voltage?
And going back to the first question... How do you select the resistors for the inputs and the loop?
