Shifting byte and remaining values
Can someone explain way the code that you see below give these results?
	byte test=00000101;
	Serial.print("the byte test is:");
	Serial.println(test);
	int x=(int)test;
	int y=(int)test<<8;
	Serial.print("the int x is:");
	Serial.println(x);
	Serial.print("the int shifted y is:");
	Serial.println(y);
	byte tost=10000001;
	int z=test+tost;
	Serial.print("the int z is:");
	Serial.println(z);
Results:
the byte test is:65
the int x is:65
the int shifted y is:16640
the int z is:194
While if i change the test to 00000001 it performs great:
changed code:
	byte test=00000001;
	int x=(int)test;
	int y=(int)test<<8;
	Serial.println(x);
	Serial.println(y);
	byte tost=10000001;
	int z=test+tost;
	Serial.println(z);
the byte test is:1
the int x is:1
the int shifted y is:256
the int z is:130
What part don't you understand?
	byte test=00000101;
Any literal starting with a 0 is interpreted as an octal value, not binary or decimal or hexadecimal.
