i know this place is where i search for info, so maybe this will help someone out.
here is some very basic, very verbose code that shows how to set the outputs of a 74hc164 shift register, and to read the 74hc164's (8 parrallel outputs, serial input) output values using a 74hc165 shift register (8 parrallel inputs, serial output). this is the beginning of concepts you would use to read a 8x8 matrix of buttons, or even drive a 8x8 matrix of led's.
this assumes a basic understanding of what a shift register is.
//164 pins
int clearPin = 2; // enablepin
int dataPin = 3;
int clockPin = 4;
//165 pins
int inclearPin = 11; // enablepin
int indataPin = 9;
int inclockPin = 10;
int inloadPin = 12; // toggling this tells the 165 to read the value into its memory for reading
int temp = 0;
//start serial
pinMode(clearPin, OUTPUT);
digitalWrite(clearPin, 1); // enable output, you could also tie this pin to VCC
pinMode(dataPin, OUTPUT);
pinMode(clockPin, OUTPUT);
//165
pinMode(inclearPin, OUTPUT);
digitalWrite(inclearPin, 0); // enable input, you could also tie this pin to GND
pinMode(indataPin, INPUT);
pinMode(inclockPin, OUTPUT);
pinMode(inloadPin, OUTPUT);
//we want to set the 164's outputs to any combination of 1's and 0's we want
//going to set the 164 outputs to 11101101 or on,on,on,off,on,on,off,on if you prefer, where on is 5v and off is grnd
//1st bit
digitalWrite(clockPin, 0);
digitalWrite(dataPin, 1);
digitalWrite(clockPin, 1);
//2nd bit
//3rd bit
//4th bit
digitalWrite(dataPin, 0);
//5th bit
//6th bit
//7th bit
//8th bit
// now its time to read the values that we outputted back in
digitalWrite(inloadPin, 0); // read into register (tells the 165 to take a snapshot of its input pins)
digitalWrite(inloadPin, 1); // done reading into register, ready for us to read
for(int i=0; i<=7; i++){ // read each of the 165's 8 inputs (or its snapshot of it rather)
// tell the 165 to send the inputs pin state
digitalWrite(inclockPin, 0);
// read the current output
temp = digitalRead(indataPin); // read the state
// tell the 165 we are done reading
digitalWrite(inclockPin, 1);
Serial.print (temp);
Serial.println ("");
Serial.println ("--------");
delay(2000);
