shiftOut - PWM?
Hey guys,
When using the shitOut function do I need to output on PWM pins or can I just use normal digital pins?
I'm using it to control This.
I thought because I'm just pulling pins high and low and sending some binary I could just use digital pins. All the examples I found on google though are using PWM pins but don't specifically say.
You can use any kind of digital pin you like. Pwm and analogRead is only available one some pins so it may be a good idea to stay away from them. Also try not to use pins 0 + 1 as they are used by Serial.
Mark
