Shinyei Dust sensor with other sensors. : HELP!!!
so I realized the other day that my dust sensor has been giving me the wrong values in the serial when I code it with my other sensors. I’m not sure as to how to fix this problem can someone help me figure this out. It is totally fine when I speak to it by itself. I think it has something to do with the timing. Here is the code
#include "SoftwareSerial.h"
#include "SD.h"
#include "Wire.h"
SoftwareSerial K_30_Serial(12,13); //Sets up a virtual serial port
 //Using pin 13 for Rx and pin 12 for Tx
byte readCO2[]={0xFE, 0X44, 0X00, 0X08, 0X02, 0X9F, 0X25}; //Command packet to read Co2 (see app note)
byte response[]={0,0,0,0,0,0,0}; //create an array to store the response
//multiplier for value. default is 1. set to 3 for K-30 3% and 10 for K-33 ICB
int valMultiplier = 1;
int pin =8; dust pin
unsigned long duration;
unsigned long starttime;
unsigned long sampletime_ms=3000;//sampe 30s ;
unsigned long lowpulseoccupancy=0;
float ratio=0;
float concentration=0;
int temperatureCommand=3;
int humidityCommand=5;
int clockPin=2;
int dataPin=3;
int val;
int ack;
float temperature;
float humidity;
const int chipSelect=53;
float refresh_rate=0.0;
long Num=1;
K_30_Serial.begin(9600);
Wire.begin();
Serial.print("Initializing SD card...");
Wire.beginTransmission(0x68); // address DS3231
  Wire.write(0x0E); // select register
  Wire.write(0b00011100); // w
 pinMode(53, OUTPUT);
pinMode(8,INPUT);
  starttime = millis();//get the current time;
pinMode (2,INPUT);
pinMode (3,INPUT);
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
return;
Serial.println("card initialized.");
File commandFile= SD.open("COMMANDS.txt");
if (commandFile)
  Serial.println("Reading Command File");
  float decade=pow(10,(commandFile.available()-1));
  while
  (commandFile.available())
    float temp= (commandFile.read()-'0');
    refresh_rate= temp* decade + refresh_rate;
    decade=decade/10;
  Serial.print("Refresh Rate=");
  Serial.print(refresh_rate);
  Serial.println("ms");
  commandFile.close();
Serial.println("Could not readd command File");
return;
File logFile=SD.open("0427.csv",FILE_WRITE);
if (logFile)
  logFile.println(",,,,");
  String header= "Num,Temperature,Humidity,CO2,Dust concentration,time";
  logFile.println(header);
  logFile.close();
  Serial.println(header);
  Serial.println ("Couldn't Open log file");
{sendRequest(readCO2);
  unsigned long valCO2 = getValue(response);
 Serial.print("Co2 ppm = ");
 Serial.println(valCO2);
delay(refresh_rate);
duration = pulseIn(pin, LOW);
lowpulseoccupancy = lowpulseoccupancy+duration;
if ((millis()-starttime) > sampletime_ms)//if the sampel time == 30s
    ratio = lowpulseoccupancy/(sampletime_ms*10.0);  // Integer percentage 0=>100
    concentration = 1.1*pow(ratio,3)-3.8*pow(ratio,2)+520*ratio+0.62; // using spec sheet curve
     Serial.print(lowpulseoccupancy);
    Serial.print(",");
    Serial.print(ratio);
    Serial.print(",");
    Serial.println(concentration);
    lowpulseoccupancy = 0;
    delay (refresh_rate);
  sendCommandSHT(temperatureCommand, dataPin, clockPin);
  waitForResultSHT(dataPin);
  val = getData16SHT(dataPin, clockPin);
  skipCrcSHT(dataPin, clockPin);
  temperature = (float)val * 0.01 - 40;
  temperature = (float)temperature;
  sendCommandSHT(humidityCommand, dataPin, clockPin);
  humidity = -4.0 + 0.0405 * val + -0.0000028 * val * val;
   Serial.print(temperature*100);
   Serial.println(humidity*100);
 // send request to receive data starting at register 0
   Wire.beginTransmission(0x68); // 0x68 is DS3231 device address
  Wire.write((byte)0); // start at register 0
  Wire.endTransmission();
  Wire.requestFrom(0x68, 3); // request three bytes (seconds, minutes, hours)
  while(Wire.available())
     int seconds = Wire.read(); // get seconds
    int minutes = Wire.read(); // get minutes
    int hours = Wire.read();   // get hours
    seconds = (((seconds & 0b11110000)>>4)*10 + (seconds & 0b00001111)); // convert BCD to decimal
    minutes = (((minutes & 0b11110000)>>4)*10 + (minutes & 0b00001111)); // convert BCD to decimal
    hours = (((hours & 0b00100000)>>5)*20 + ((hours & 0b00010000)>>4)*10 + (hours & 0b00001111)); // convert BCD to decimal (assume 24 hour mode)
 Serial.print(hours); Serial.print(":"); Serial.print(minutes); Serial.print(":"); Serial.println(seconds);
delay (1000);
 String dataString= String(Num)+","+String(temperature)+","+String(humidity)+","+String(valCO2)+","+String(concentration)+","+String (hours)+":"+String(minutes)+":"+String (seconds);
      File logFile= SD.open("0427.csv",FILE_WRITE);
  if (logFile)
logFile.println(dataString);
logFile.close();
Serial.println(dataString);
  Serial.println("couldn't open log File");
Num++;
void sendRequest(byte packet[])
 while(!K_30_Serial.available()) //keep sending request until we start to get a response
 K_30_Serial.write(readCO2,7);
 delay(50);
 int timeout=0; //set a timeoute counter
 while(K_30_Serial.available()< 7) //Wait to get a 7 byte response
 timeout++;
 if(timeout>10) //if it takes to long there was probably an error
 while(K_30_Serial.available()) //flush whatever we have
 K_30_Serial.read();
 break; //exit and try again
 delay(50);
 for (int i=0; i <7; i++)
 response[i]=K_30_Serial.read();
unsigned long getValue(byte packet[])
 int high = packet[3]; //high byte for value is 4th byte in packet in the packet
 int low = packet[4]; //low byte for value is 5th byte in the packet
 unsigned long val = high*256 + low; //Combine high byte and low byte with this formula to get value
 return val* valMultiplier;
int shiftIn(int dataPin, int clockPin, int numBits) {
  int ret = 0;
  for (int i=0; i<numBits; ++i) {
    digitalWrite(clockPin, HIGH);
    //delay(10); not needed :)
    ret = ret*2 + digitalRead(dataPin);
    digitalWrite(clockPin, LOW);
  return(ret);
// send a command to the SHTx sensor
void sendCommandSHT(int command, int dataPin, int clockPin) {
  int ack;
  // transmission start
  pinMode(dataPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  digitalWrite(dataPin, HIGH);
  digitalWrite(dataPin, LOW);
  // shift out the command (the 3 MSB are address and must be 000, the last 5 bits are the command)
  shiftOut(dataPin, clockPin, MSBFIRST, command);
  // verify we get the right ACK
  pinMode(dataPin, INPUT);
  ack = digitalRead(dataPin);
  if (ack != LOW)
    Serial.println("ACK error 0");
  if (ack != HIGH)
    Serial.println("ACK error 1");
// wait for the SHTx answer
void waitForResultSHT(int dataPin) {
  int ack;
  for(int i=0; i<100; ++i) {
    delay(10);
    if (ack == LOW)
  if (ack == HIGH)
    Serial.println("ACK error 2");
// get data from the SHTx sensor
int getData16SHT(int dataPin, int clockPin) {
  int val;
  // get the MSB (most significant bits)
  val = shiftIn(dataPin, clockPin,8);
  val *= 256; // this is equivalent to val << 8;
  // send the required ACK
  // get the LSB (less significant bits)
  val |= shiftIn(dataPin, clockPin,8);
  return val;
// skip CRC data from the SHTx sensor
void skipCrcSHT(int dataPin, int clockPin){
Rewrite the K_30 timeout code. 10 tries look much too short to me, and reading after a break most probably returns bad values. It can be assumed that the sensor honors every request, and sends the requested number of bytes. You have to take care to skip all bytes of a failed transmission, before you start the next try.
SoftwareSerial is known as unreliable, have you tried other libraries (AltSoftSerial...) already?
