wwb00
May 23, 2015, 4:49pm
#1
The purpose of this program is an basis for an game that I will be developing that needs ship movement. This will be a block, of my later program. If the rButton is pushed, it should move the ship one to the right and vise versa, except if it is at the ends of the LCD. What is wrong with the program. When I push one of the buttons, it does nothing. Are the buttons setup wrong, or is there somthing wrong with the program itself. Thanks-Ben
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
byte Ship[8] = {
B00000,
B00000,
B00100,
B00100,
B01010,
B01010,
B11111,
B00000
int lButton = 13;
int rButton = 6;
int lState = 0;
int rState = 0;
int shipPlacement=0;
boolean lTrue= false;
boolean rTrue = false;
pinMode(lButton, INPUT);
pinMode(rButton, INPUT);
lcd.createChar(0, Ship);
lcd.begin(16, 2);
lState=digitalRead(lButton);
rState=digitalRead(rButton);
if(rState==HIGH){
if(shipPlacement=15){
lcd.setCursor(shipPlacement,1);
lcd.write((byte)0);
delay(250);
else if(shipPlacement<15){
shipPlacement++;
lcd.write((byte)0);
delay(250);
else if(lState==HIGH){
if(shipPlacement=0){
lcd.write((byte)0);
delay(250);
else if(shipPlacement>0){
shipPlacement--;
lcd.write((byte)0);
delay(250);
else{
lcd.write((byte)0);
shipPlacement=15
shipPlacement=0
These seem to be missing an = somewhere.
wwb00
May 23, 2015, 4:55pm
#3
HazardsMind:
shipPlacement=15
shipPlacement=0
Thanks I will try. If not I will let you know
wwb00
May 23, 2015, 4:57pm
#4
I tried the solution, and the “ship” icon, will not move when the button is pressed. Thank you though
byte Ship[8] = {
B00000,
B00000,
B00100,
B00100,
B01010,
B01010,
B11111,
B00000
int lButton = 13;
int rButton = 6;
int lState = 0;
int rState = 0;
lcd.begin(16, 2);
if(rState==HIGH){
if(shipPlacement==15){
lcd.write((byte)0);
delay(250);
shipPlacement++;
lcd.write((byte)0);
delay(250);
if(shipPlacement==0){
lcd.write((byte)0);
delay(250);
shipPlacement--;
lcd.write((byte)0);
delay(250);
else{
lcd.write((byte)0);
–Fixed Syntax Code
I would put these two lines of code
in the beginning of your main loop, too.
because
lcd.begin(16, 2);
the code inside the setup will only run once.
wwb00
May 23, 2015, 5:03pm
#6
Thank you!!! It works, I knew it had to be an syntax error!!
