shocks in BDC...
hello Guys
i programmed a Brushless motor with this code :
#include <SoftwareSerial.h>
#include <Servo.h>
SoftwareSerial esp8266(2,3);
Servo brush_1;
char c;
int p=0;
char b;
int i=0;
int speed;
void arm(){
// arm the speed controller, modify as necessary for your ESC
setSpeed(0);
delay(1000); //delay 1 second, some speed controllers may need longer
void setSpeed(int speed){
int angle = map(speed, 0, 100, 0, 180);
brush_1.write(angle);
pinMode(12,OUTPUT);
brush_1.attach(12);
arm();
if(Serial.available()){
b=Serial.read();
if(b=='^'){
speed=speed+5;
// brush_1.write(i);
setSpeed(speed);
delay(10);
if(b=='&')
speed=speed-5;
setSpeed(speed);
Serial.println(speed);
the problem is that when i change the speed of motor it have shocks...for example when the speed change from 60 to 65....
what can i do for it?
i don't want to use PID methods...
tnx for your time
  pinMode(12,OUTPUT);
  brush_1.attach(12);
arm();
Well, the compiler barfed on that, didn't it?
Please post the actual you're having problems with, but this time in code tags.
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Why do you have a SoftwareSerial instance called esp8266 which is never used? Using Servo.h and SoftwareSerial.h together often causes problems so if you're not going to use it then gt rid of it.
Steve
