Grumpy_Mike:
First of all this is illegal in most countries.
Read Part 15 Devices of FCC regs: https://www.fcc.gov/media/radio/low-power-radio-general-information
Grumpy_Mike:
Hint, do something with the result of your analogue read value.
Ok will work on that.
Grumpy_Mike:
OCR1A = 14; // 530 MHz
What makes you think you can generate 530MHz from a processor that is only running at 16MHz?
Because this works (actually you helped someone in previous thread with similar):
const byte ANTENNA = 9;
unsigned long A = calcDelayTimeForFreq(440);
unsigned long B = calcDelayTimeForFreq(494);
unsigned long C = calcDelayTimeForFreq(523);
unsigned long D = calcDelayTimeForFreq(587);
unsigned long E = calcDelayTimeForFreq(659);
unsigned long F = calcDelayTimeForFreq(699);
unsigned long G = calcDelayTimeForFreq(784);
unsigned long _A2 = calcDelayTimeForFreq(880);
unsigned long rest = 1;
unsigned long q = 652;
unsigned long e = q/2;
unsigned long s = e/2;
unsigned long t = s/2;
unsigned long h = q*2;
unsigned long f = q*4;
// set up Timer 1
TCCR1A = _BV (COM1A0); // toggle OC1A on Compare Match
TCCR1B = _BV(WGM12) | _BV(CS10); // CTC (clear timer), no prescaler (no reduction of 16 mHz frequency)
OCR1A = 14; // compare A register value to 10 (zero relative)
} // end of setup
void tone(unsigned long dTime, unsigned long playTime) {
unsigned long end = millis() + playTime;
while (end > millis()) {
pinMode (ANTENNA, OUTPUT);
delayMicroseconds(dTime);
pinMode (ANTENNA, INPUT);
void note(unsigned long dTime, unsigned long playTime) {
tone(dTime,playTime-50);
tone(rest,50);
unsigned long calcDelayTimeForFreq(unsigned long freq) {
return 500000/freq;
void notes() {
note(C,q);
note(G,q);
note(_A2,q);
note(F,q);
note(E,q);
note(D,q);
void locateTone() {
note(A,t);
note(B,t);
note(C,t);
note(D,t);
note(E,f);
note(D,t);
note(C,t);
note(B,t);
notes();
