Shortened code for TM1637 scoreboard
I recently created a smart dartboard for an independent study that automatically updates the score when a target is triggered. I believe the code I created is more efficient than others in the library. Let me know if it works for you.
#include <TM1637Display.h>
#define CLK_PIN 2 // Define CLK pin for TM1637 display
#define DIO_PIN 3 // Define DIO pin for TM1637 display
#define BUTTON_PIN_ONE 4 // Define button pin
#define BUTTON_PIN_TWO 5 // Define button pin
TM1637Display display(CLK_PIN, DIO_PIN);
int scoreOne = 0; // Initial score
int scoreTwo = 0;
pinMode(BUTTON_PIN_ONE, INPUT_PULLUP); // Set button pin as input with pull-up resistor
pinMode(BUTTON_PIN_TWO, INPUT_PULLUP); // Set button pin as input with pull-up resistor
display.setBrightness(0x0f); // Set display brightness (0-7), adjust as needed
display.showNumberDec(0000); // Display initial score
Serial.println("Welcome to Smart Dart");
if (digitalRead(BUTTON_PIN_ONE) == LOW) { // Check if the button is pressed
delay(50); // Debounce delay
scoreOne++; // Increment the score // Update the display with the new score
delay(500); // Optional delay to avoid multiple increments from a single press
if (digitalRead(BUTTON_PIN_TWO) == LOW) { // Check if the decrease button is pressed
scoreTwo++; // Decrement the score // Update the display with the new score
delay(500); // Optional delay to avoid multiple decrements from a single press
display.showNumberDec(scoreTwo * 100 + scoreOne);
Your topic has been moved as it does not indicate a problem with the Arduino CLI.
Please edit your post, select all code and click the <CODE/> button; next save your post. This will apply code tags which makes the code easier to read and copy and the forum software will display it correctly.
