Should be a simple Button question to answer
Below is my code. I'm trying to make sub menus and for some reason the buttons always returns the main menu options.
I figured it'd be as easy as making a function called "readButtons();" and use it to call for the button states and use if statements to act on the button pressed. The issue is that when I select a menu it prints out the menu title and I want to use the readButtons(); there and do other things however when i press the buttons it just puts me back to the main menu. I thought when you did a function call it would go to the function code and execute it and I don't know what i'm doing wrong to keep the button reading to the current function.
this is the code for the main menu
#include <LiquidCrystal.h>
// Initialize the library with the numbers of the interface pins
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
//States for the menu.
int currentMenuItem = 1;
int lastState = 0;
int state = 0;
int airTemp1 = 45;
//Set the characters and column numbers.
lcd.begin(16, 2);
//Print default title.
clearPrintTitle();
delay(2000);
displayMenu(currentMenuItem);
//Call the main menu.
mainMenu();
void mainMenu() {
buttonRead();
//If we are out of bounds it rolls over.
if (currentMenuItem < 1) {
currentMenuItem = 4;
if (currentMenuItem > 4) {
//If we have changed Index, saves re-draws.
if (state != lastState) {
if (state == 1) {
//If Up
currentMenuItem = currentMenuItem - 1;
} else if (state == 2) {
//If Down
currentMenuItem = currentMenuItem + 1;
} else if (state == 5) {
//If Selected
selectMenu(currentMenuItem);
//Save the last State to compare.
lastState = state;
//Small delay
delay(5);
void buttonRead() {
//State = 0 every loop cycle.
state = 0;
//Refresh the button pressed.
int x = analogRead (0);
//Set the Row 0, Col 0 position.
lcd.setCursor(0,0);
//Check analog values from LCD Keypad Shield
if (x < 80) {
//Right
state = 4;
} else if (x < 200) {
//Up
state = 1;
} else if (x < 400){
//Down
state = 2;
} else if (x < 600){
//Left
state = 3;
} else if (x < 800){
//Select
state = 5;
//Display Menu Option based on Index.
void displayMenu(int x) {
switch (x) {
case 1:
clearPrintTitle();
lcd.print ("-> Temperature");
case 2:
clearPrintTitle();
lcd.print ("-> Menu Option 2");
case 3:
clearPrintTitle();
lcd.print ("-> Menu Option 3");
case 4:
clearPrintTitle();
lcd.print ("-> Menu Option 4");
//Print a basic header on Row 1.
void clearPrintTitle() {
lcd.clear();
lcd.setCursor(0,0);
lcd.print(" ReaperFarms ");
lcd.setCursor(0,1);
//Show the selection on Screen.
void selectMenu(int x) {
switch (x) {
case 1:
clearPrintTitle();
lcd.print ("Temp:");
lcd.setCursor(0,2);
lcd.print("Set -->");
lcd.setCursor(9,2);
lcd.print(airTemp1);
while (int a = 0) {
x = analogRead(0);
if (x < 80) {
//Right
else if (x < 200) {
//Up
airTemp1++;
lcd.setCursor(9,2);
else if (x < 400){
//Down
airTemp1--;
lcd.setCursor(9,2);
else if (x < 600){
//Left
else if (x < 800){
//Select
mainMenu();
case 2:
clearPrintTitle();
lcd.print ("Selected Opt 2");
//Call the function that belongs to Option 2
case 3:
clearPrintTitle();
lcd.print ("Selected Opt 3");
//Call the function that belongs to Option 3
case 4:
clearPrintTitle();
lcd.print ("Selected Opt 4");
//Call the function that belongs to Option 4
while (int a = 0)
How many times do you think that loop is going to iterate?
Please remember to use code tags when posting code.
Also, unless you really know what you're doing, don't use recursion.
Why does readButton() fk with the LCD cursor? Rename your function to readButtonAndFuckWithLCDCursorUselessly(), or stop fking with the LCD cursor in the function.
