I'm going to be controlling some HO Scale Traffic Lights anywhere from 2 to 8 feet away from the Arduino board. The lights run on 5 VDC and I'm programming the Output Pins to go to Ground to turn them on. Probably about 5ma or less for each LED. I plan to run CAT 5 wire from terminal strips that are wired to the Arduino. Should I be concerned about the Trains running around the track and generating "noise"? It's been suggested to me that I add a small transistor (2N2222 or equiv.) to each output line at the Arduino and then run the wires from that. Help and suggestions are appreciated. I'm still a newbie at this. Thanks!
An Arduino output pin is not sensitive for noise.
But I think many of us like to isolate the bad world outside from a direct path to the microcontroller on the Arduino board.
However, a few leds should be no problem at all.
Are you using one led per output pin ? I you want to use 5 or more per pin, you better use a transistor.
The wire pairs inside a CAT 5 cable are twisted pair, so you should perhaps be sure that each LED you feed uses a separate twisted pair to deliver the 5v. and ground. That would guarantee you pretty good noise immunity.
Good Luck
John Doner
For all unused pins, make them inputs with the internal pullup resistors enabled, e.g.
pinMode(5, INPUT_PULLUP);
pinMode(6, INPUT_PULLUP);
pinMode(7, INPUT_PULLUP);
If you are concerned with noise from trains etc running around the cable, get a shielded cable and connect the shield to ground.
