Should I use a boolean for this? Why is there a delay here?
I have a bunch of momentary switches and I am having some trouble with figuring out how I should do my code for them. What I want to do is went a button is pressed it turns on, off, or makes the light inside the button flash. Then I want to execute a keyboard press. Then when pressed again I want it to change the light inside the button and execute a different keyboard press. What is the best way to do this? I have 6 momentary switches and 2 latching switches. I am currently waiting for help with the momentary ones so I figured I would try the latching ones. The first time the keyboard press on the latching switch executes happens immediately but the next one has like a 25 second delay in it. I didn't program that delay in and I can't figure out why it is happening. Thanks for your time and for any help you can provide. For those of you who are interested I am trying to make a control panel for No Limits 2 I will put a link below for a video that has a panel similar to mine in it. Code is also below. Thanks!
const int PowerSwitch = 12;
const int Floorlight = 11;
const int FloorButton = 10;
const int Stopresetlight = 9;
const int StopresetButton = 8;
const int Stoplight = 7;
const int StopButton = 6;
const int GatesSwitch = 5;
const int Harnesslight = 4;
const int HarnessButton = 3;
const int Dispatchlight = 2;
const int DispatchButton = 1;
boolean DispatchButtonbuttonPressed;
boolean GatesSwitchbuttonPressed;
#include <Keyboard.h>
   pinMode(Dispatchlight,OUTPUT);
  pinMode(DispatchButton, INPUT_PULLUP);
  pinMode(Harnesslight, OUTPUT);
  pinMode(HarnessButton, INPUT_PULLUP);
  pinMode(GatesSwitch, INPUT_PULLUP);
  pinMode(StopButton, INPUT_PULLUP);
  pinMode(Stoplight, OUTPUT);
  pinMode(StopresetButton, INPUT_PULLUP);
  pinMode(Stopresetlight, OUTPUT);
  pinMode(FloorButton, INPUT_PULLUP);
  pinMode(Floorlight, OUTPUT);
  pinMode(PowerSwitch, INPUT_PULLUP);
  digitalWrite(DispatchButton, HIGH);
  digitalWrite(HarnessButton, HIGH);
  digitalWrite(GatesSwitch, HIGH);
  digitalWrite(StopButton, HIGH);
  digitalWrite(StopresetButton, HIGH);
  digitalWrite(FloorButton, HIGH);
  digitalWrite(PowerSwitch, HIGH);
void loop(){
if(digitalRead(GatesSwitch) == LOW) {
  GatesSwitchbuttonPressed = true;
  }else{
    GatesSwitchbuttonPressed = false;
if(GatesSwitchbuttonPressed == true){
 Keyboard.press(0xCB);
        Keyboard.release(0xCB);
        digitalWrite(Dispatchlight, LOW);
        digitalWrite(Stopresetlight,LOW);
        digitalWrite(Harnesslight,LOW);
        digitalWrite(Floorlight,LOW);
        digitalWrite(Stoplight,LOW);
}if(GatesSwitchbuttonPressed == false){
   Keyboard.press(0xCC);
        Keyboard.release(0xCC);
if (digitalRead(DispatchButton) == HIGH) {
  DispatchButtonbuttonPressed = true;
  DispatchButtonbuttonPressed = false;
    if(DispatchButtonbuttonPressed == true) {
       Keyboard.press(0xCD);
        Keyboard.release(0xCD);
        digitalWrite(Dispatchlight, HIGH);
        digitalWrite(Stopresetlight,HIGH);
        digitalWrite(Harnesslight,HIGH);
        digitalWrite(Floorlight,HIGH);
        digitalWrite(Stoplight,HIGH);
   else {
The delay(500) you are using is slowing things down. I suggest using Millis or #define INTERVAL_MESSAGE1
So the delay is for blinking the lights in a certain pattern. Can you show me how #define INTERVAL_MESSAGE1 would fit in my code. Does it go above the setup or in the Void Loops section? The lights will always be blinking at 500 milliseconds on and 500 milliseconds off if that simplifies anything. Thanks for your help!
You should think your code as a finite state machine. There are some very good tutorials about this in the relevant section of the forum.
