Sorry, in advance, I don't want this to sound like I am trashing IDE 2. There are a lot of things I like about it and all of my Current Arduino builds are done using it.
But when there are some fundamental issues like:
Issues with copy and paste out of the Serial monitor. Where many of these issues were reported at least a couple of years ago.
So I wonder if I should report things like: (Some I know have been reported before)
Arduino Lost my settings
Today: It appears like Arduino lost all of my user settings. I had done several compiles and the like, I opened up another window, and noticed that all of my Arduino windows are now drawn using the light theme where I was using the dark theme. Also I had the Serial monitor on the right hand side. Compiler warning are now back to none...
I can go through and reset my settings (again). This has happened a few times before.
Arduino appears to semi-hang
Most of the time this happens if my Windows PC has gone to sleep. Some of the times things just don't work right. like the Serial monitor can not connect back up to Serial port. Other times nothing works, and cannot even close windows, without going to task manager and killing the process.
Opens up Sketches on another drive Read only
Reported earlier. The one I reproduce this, is I keep most of my Github projects on another drive (d:\github...). For example I have my Arduino GIGA example sketches on d: and I create a junction to it:
C:\Users\kurte\Documents\Arduino>dir arduino_*
Volume in drive C is OS
Volume Serial Number is 7E8D-E873
Directory of C:\Users\kurte\Documents\Arduino
02/06/2024 01:17 PM <JUNCTION> arduino_GIGA [d:\github\Arduino_GIGA-stuff\sketches]
05/21/2024 08:37 AM <DIR> Arduino_UNOR4
0 File(s) 0 bytes
2 Dir(s) 77,057,179,648 bytes free
Now if I open up sketches using the
The project opens up Read only and I cannot edit anything.
However if I then close the project and reopen it from the open recent it then opens up
fine and I can edit the project...
Sorry, I know I am just sort of whining.
Edit: Forgot to mention I am running the nightly build 20240630
