I'm creating a sketch in which I want diagnostic output (to the Serial Monitor) to be generated ONLY when I'm developing the code and have the Arduino connected to my computer via the USB cable.
When I've disconnected the cable and am running the Arduino from battery I don't want it to even TRY to access the Serial Monitor, but I sure don't want to have to manually go through the sketch and either delete or comment-out each and every Serial instruction.
I'm OK with doing an additional compile to prepare it for battery operation, so that it will NOT generate the Serial instructions.
What I've done is use a #define statement like this:
//#define IF_SERIAL_ENABLED
// Replace the above with #define IF_SERIAL_ENABLED //
// if you want all Serial.print calls to be ignored (not even compiled).
And then, throughout the code, I do it like this:
// Prepare for serial text output
IF_SERIAL_ENABLED Serial.begin(115200);
// Wait for Serial to become active
IF_SERIAL_ENABLED while (!Serial)
IF_SERIAL_ENABLED delay(10);
IF_SERIAL_ENABLED Serial.println("MY PROGRAM");
The idea is that if IF_SERIAL_ENABLE is defined as being just blank text then the related Serial command is recognized as being an actual instruction and is compiled by the compiler. For example:
actually becomes just
since the IF_SERIAL_ENABLE gets turned into just a space character during preprocessing for the compiler.
ON THE OTHER HAND, if I have . . .
then every instance of IF_SERIAL_ENABLED should get replaced with just the "//" and basically turn the entire line into a comment statement and be ignored by the compiler.
Something like:
becomes . . .
// Serial.begin(115200);
That's my theory of how it ought to operate. But that's not what actually happens.
Whether I use . . .
or
all of the Serial instructions, like . . .
do indeed get compiled and become part of the sketch.
While trying to figure out why it wasn't working as I expected, I tried . . .
#define IF_SERIAL_ENABLED crap
and sure enough the compiler reported it as an error, that it didn't recognize the word "crap".
I tried . . .
i.e. just a ingle slash, and that resulted in an error . . .
expected primary-expression before '/' token
So, why isn't this working as I'm expecting (hoping) it to work?
Is there some other way to basically have Serial instructions in the code that will get executed when the USB cable is connected (and therefore has access to the Serial Monitor) but have those Serial instructions NOT executed when running by battery and no USB cable connected (so there's no access to the Serial Monitor)?
