Show code only when plugged into a computer,
Hello,
I have a question about Arduino code and serial monitoring,
I don't know if its a placebo effect playing games with my head, but when I have some larger projects with serial, even when not plugged into a computer the code seems a bit slower.
Does Arduino run the serial data/code when not plugged into a PC and only getting VCC input?
if this is so, is there a way to only run the serial codes whilst plugged into a PC?
Thanks
Shaun.
The Arduino always runs whatever code is programmed on it when it is powered on. When plugged into a PC, the only difference is that the USB-Serial chip on the board can be used to send and receive data to/from it, acting as a translator.
Only native USB devices such as the Arduino Leonardo communicate with the computer to tell it what kind of device it is (Keyboard, MIDI instrument etc.), so these are the only boards which "know" when they are communicating with a computer.
The other Arduinos send out data whenever Serial.print is called, without checking for any connection, like talking to a brick wall. So they execute every time.
Every Serial.print takes time, and for the somewhat classic 9600 baud rate, that means that sending 9600 characters would take about ten seconds, sending 960 would take a full second etc.; increasing the baud rate would take less time but it's still unnecessarily slower to print data when no one is listening.
If you are using a more common board like the UNO or Nano, a possible solution could be to have a global flag that only becomes true when something is received through serial and have all Serial.print instructions locked behind an if-statement.
bool is_Serial_open = false;
  if (Serial.available()) {
    is_Serial_open = true;
  if (is_Serial_open) {
    Serial.println("Serial opened");
The Serial.available() function returns how many bytes have been received through serial. If any are received, it will return a value greater than 0 and the if-statement will execute because it evaluates to "true".
This sketch does nothing until you send something through the serial monitor (a character, a newline, anything), after which the flag becomes true and the print statement executes in a loop.
Thankyou kindly for this code, I will implement this :slight_smile:
