I'm hitting another shortfall in my "programming skills".
What I want to do seems to be quite simple but I spent now more then 3 hours on it and it still doesn't work.
What I want to achief is this:
The program runs as per normal but when I press the #-key on the keypad a function (MainMenu()) will be called and this in turn will show the main menu on an LCD for 5 seconds and will then revert back to it's original state.
The program I wrote works to a certain extend: It shows the Serial.println("It works") for one clock cycle and that's it. So, calling the function is not a problem but it will only show briefly; What I'm I doing wrong?
Here is the simple sketch:
/* Code for 4x4 Keypad with menu. http://www.instructables.com/id/Connecting-a-4-x-4-Membrane-Keypad-to-an-Arduino */
#include <Keypad.h>
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
char keys[ROWS][COLS] = {
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'*','0','#','D'}
char KeyValue;
byte rowPins[ROWS] = {5, 4, 3, 2}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {9, 8, 7, 6}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
// Time variables
unsigned long startMillis; //some global variables available anywhere in the program
unsigned long currentMillis;
const unsigned long period = 1000; //the value is a number of milliseconds
void setup(){
startMillis = millis(); //initial start time
KeyValue=keypad.getKey();
if(KeyValue == '#') {
MainMenu();}
else {
Serial.println("Nothing pressed");
//XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
void MainMenu(){
currentMillis = millis();
if ((currentMillis - startMillis) >= period) {
Serial.println("It works");
startMillis = currentMillis;
In all paths your KeyValue = keypad.getKey( ); is right after you set startMillis.
Re-think about where that statement is and how it affects your timing.
I moved the startMillis = millis(); to the function where I call to open up the menu. However, now I can't even call the function anymore.
From what you said you basically stated that the startMillis needs to be started when the functions opens, hence why I moved it out of the setup() function.
Could you please elaborate on that a bit more?
#include <Keypad.h>
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'*','0','#','D'}
char KeyValue;
// Time variables
void setup(){
//startMillis = millis(); //initial start time
MainMenu();}
else {
void MainMenu(){
I've got it working now with a FOR-loop.
Although it has the planned outcome I was hoping for it is still not good enough as whilst the program runs the FOR-loop nothing else is happening.
If I could replace the FOR-loop with the millis() function then it would be great.
Here's my updated code:
