Show more than 8 lines of text
Hi all! Earlier i have 2 panels but got some issuse with a megas limited memory so i use only 1 panel. Work fine so far.
Uploaded a sketch scroll up text. Everything fine. Changed some codes to adding more lines.
That I got problem, i added 11 lines of text, but on panel that show only 8 lines then start over.
That is 11 lines.
#define F2(progmem_ptr) (const __FlashStringHelper *)progmem_ptr
#define F3(progmem_ptr) (const __FlashStringHelper *)progmem_ptr
#define F4(progmem_ptr) (const __FlashStringHelper *)progmem_ptr
#define F5(progmem_ptr) (const __FlashStringHelper *)progmem_ptr
#define F6(progmem_ptr) (const __FlashStringHelper *)progmem_ptr
#define F7(progmem_ptr) (const __FlashStringHelper *)progmem_ptr
#define F8(progmem_ptr) (const __FlashStringHelper *)progmem_ptr
#define F9(progmem_ptr) (const __FlashStringHelper *)progmem_ptr
#define F10(progmem_ptr) (const __FlashStringHelper *)progmem_ptr
#define F11(progmem_ptr) (const __FlashStringHelper *)progmem_ptr
const char str[] PROGMEM = "$P1 Nick 1";
const char str2[] PROGMEM = "$P2 Varv 1";
const char str3[] PROGMEM = "$P3 Nick 2";
const char str4[] PROGMEM = "$P4 Varv 2";
const char str5[] PROGMEM = "$P5 Nick 3";
const char str6[] PROGMEM = "$P6 Varv 3";
const char str7[] PROGMEM = "$P7 Nick 4";
const char str8[] PROGMEM = "$P8 Varv 4"; // <- Stops at this line and start over
const char str9[] PROGMEM = "$P9 Nick 5";
const char str10[] PROGMEM = "$P10 Varv 5";
const char str11[] PROGMEM = "- - - - - - - ";
  matrix.setTextColor(matrix.ColorHSV(hue, 100, 255, false));
  matrix.setCursor(0, textY);
  matrix.print(F2(str));
  matrix.setCursor(0, textY+8);
  matrix.print(F3(str2));
  matrix.setCursor(0, textY+16);
  matrix.print(F4(str3));
  matrix.setCursor(0, textY+24);
  matrix.print(F5(str4));
  matrix.setCursor(0, textY+32);
  matrix.print(F6(str5));
  matrix.setCursor(0, textY+40);
  matrix.print(F7(str6));
  matrix.setCursor(0, textY+48);
  matrix.print(F8(str7));
  matrix.setCursor(0, textY+56);
  matrix.print(F9(str8));
  matrix.setCursor(0, textY+64);
  matrix.print(F10(str9));
  matrix.setCursor(0, textY+72);
  matrix.print(F11(str10));
  // Move text up (w/wrap), increase hue
  if((--textY) < (-matrix.height()))
    textY = matrix.height();
How many lines did you have before the change? Somewhere in the code that you did not post lies the answer to your problem.
From start it was 4 lines, i added 2 lines (6 lines), ok so far, adding 2 more (8), ok so far, adding 3 more, there is problem. I have no clue. had checked the code many times.
Why do you think that you need so many identical defined macros? Can't you just define it once and use it over and over?
Delta_G:
Hm, Im not a expert of programming, still learning. How can I do that?
Its planned to use for show Nickname and lap time for RC car.
A example that i think (using serial, but ill do it later):
1 DragonII
00:09:354 L:5 (L means laps count)
2 Janne
00:10:410 L:4 etc up to 5 players.
Any solution?
/DragonII
DragonII:
How can I do that?
Just use the same macro for ALL text...
#define FS(x) (const __FlashStringHelper *)(x)
Serial.print(FS(SomeString));
Serail.print(FS(AnotherString));
Serial.print(FS(JustFoundAnotherString));
//etc
And what the, "Mega's limited amount of memory"!? I'm not sure what you're doing but a Mega has a ton of memory compared to a Uno. And I rarely fill up an Uno!
septillion:
Hm, someone said if use a 64*32 RGB panel= (64x32x3=6144) so it will be ok. If i adding 1 more (64x32 too and chained together to a 64x64 or 128x32) so it will be 12288.
References to another link: Cloned display panels - LEDs and Multiplexing - Arduino Forum
And a movie: https://youtu.be/uHXXFyOAQ9E
If you want all of that in memory, yes, you need a lot. But I would not start a project that uses so much memory without understanding it full. As always, baby steps :slight_smile:
As I said earlier, so I have to use ONE panel, not two and make it scrollable text.
If you saw movie on link, you see that text scrolling and stop at line 8 and start over.
The text will be controlled by serial (other software), but will add it later.
