show motor speed , distance it has travelled on laptop screen wirelessly
hi everyone,, i'm using 'motor with encoder' and 'arduino' as a controller and i want to show motor( speed , distance it has travelled) on laptop screen wirelessly?
If you just want to know whether it is possible, yes. If you want help doing it, what have you done?
Did you have a question?
i want to know how can i do this ?
Where's the data for your robot ? (schematic, datasheets, description etc.etc. etc.)
How did you come by this idea yet with so little details to disclose? Did you get it from a professor?
k7aled2009:
Incrementally. Decide exactly what you want your project to do. Identify the sensors and actuators it will need to do it. Design the control algorithm which will define what the project does based on the sensor inputs. Discover how to connect those sensors and actuators to the Arduino, and how to control and manage them from the Arduino software. Add the code to implement your control algorithm. Test. Fix. Repeat until it works well enough.
