Show warnings for different variable types assignment
In c++ i can assign/compare a value from a variable type to another, even regardless of the byte size. Sometimes useful, sometimes a mess.
Obviously, casting is the solution. But nobody's perfect, so, i make mistakes.
Wrong code, deserves warnings:
int una =3;
float dues;
adeu = hola;
int tres = 4;
long int quatre = tres;
I wanna know whether is there a way to see compiler warnings regarding of this:
Thank you.
int una =3;
float dues;
adeu = hola; // <----
int tres = 4;
Surely you get this:
Scratchpad:3:1: error: 'adeu' does not name a type
 adeu = hola;
exit status 1
There's nothing wrong with this, so I would not expect an error or warning.
The implicit conversion rules are well-defined. Why would you expect a warning?
