Showbmp not displaying when combined with Sim800L
I am trying to combine the code of Sim800L with showbmp and the images are not getting loaded . The entire snipped of showbmp is getting skipped .
  while(!Serial);
  // Initialize the hardware Serial1
  Serial1.begin(9600);
  Serial1.flush();
  Wire.begin();
bytes, debug disabled
  sim800l = new SIM800L((Stream *)&Serial1, SIM800_RST_PIN, 200, 1500);
  // Equivalent line with the debug enabled on the Serial
  // sim800l = new SIM800L((Stream *)&Serial1, SIM800_RST_PIN, 200, 512, (Stream *)&Serial);
  // Setup module for GPRS communication
  tft.reset();
    ID = tft.readID();
    Serial.print("TFT ID = 0x");
    Serial.println(ID, HEX);
    //    if (ID == 0xD3D3) ID = 0x9481; // write-only shield
    if (ID == 0xD3D3) ID = 0x9486; // write-only shield
    tft.begin(ID);
    tft.setRotation(1);
    tft.fillScreen(BLACK);
    tft.println("SIM800L initailizing");
    root = SD.open(namebuf);
    pathlen = strlen(namebuf);
  // Initialize SIM800L driver with an internal buffer of 200 bytes and a reception buffer of 512 bytes, debug disabled
startMillis = millis();
Serial.println("start millis ");
Serial.println(startMillis);
// adimage();
  setupModule();
  Serial.println("inside void loop");
showimage(); // to show image
  sim800l->disconnectGPRS();
  bool connected = false;
  for(uint8_t i = 0; i < 5 && !connected; i++) {
    connected = sim800l->connectGPRS();
  // Check if connected, if not reset the module and setup the config again
  if(connected) {
    Serial.print(F("GPRS connected with IP "));
    Serial.println(sim800l->getIP());
    Serial.println(F("GPRS not connected !"));
    Serial.println(F("Reset the module."));
    sim800l->reset();
    setupModule();
    return;
  currentMillis= millis();
   if (currentMillis - startMillis > period)  //test whether the period has elapsed
  // ping to get data
    Serial.println("no active ping");
  // Close GPRS connectivity (5 trials)
  bool disconnected = sim800l->disconnectGPRS();
  if(disconnected) {
    Serial.println(F("GPRS disconnected !"));
    Serial.println(F("GPRS still connected !"));
  // Go into low power mode
  // End of program... wait...
  //while(1);
void setupModule() {
    // Wait until the module is ready to accept AT commands
  while(!sim800l->isReady()) {
    Serial.println(F("Problem to initialize AT command, retry in 1 sec"));
  Serial.println(F("Setup Complete!"));
  tft.println("Setup Complete!");
  // Wait for the GSM signal
  uint8_t signal = sim800l->getSignal();
  while(signal <= 0) {
  Serial.print(F("Signal OK (strenght: "));
  Serial.print(signal);
  Serial.println(F(")"));
  // Wait for operator network registration (national or roaming network)
  NetworkRegistration network = sim800l->getRegistrationStatus();
  while(network != REGISTERED_HOME && network != REGISTERED_ROAMING) {
  Serial.println(F("Network registration OK"));
  // Setup APN for GPRS configuration
  bool success = sim800l->setupGPRS(APN);
  while(!success) {
    delay(5000);
  Serial.println(F("GPRS config OK"));
showimage(){
Serial.println("inside show image");
  char *nm = namebuf + pathlen;
    File f = root.openNextFile();
    uint8_t ret;
    uint32_t start;
    if (f != NULL) {
#ifdef USE_SDFAT
        f.getName(nm, 32 - pathlen);
#else
        strcpy(nm, (char *)f.name());
#endif
        f.close();
        strlwr(nm);
        if (strstr(nm, ".bmp") != NULL && strstr(nm, NAMEMATCH) != NULL) {
            Serial.print(namebuf);
            Serial.print(F(" - "));
            tft.fillScreen(0);
            start = millis();
            ret = showBMP(namebuf, 5, 5);
            switch (ret) {
                case 0:
                    Serial.print(millis() - start);
                    Serial.println(F("ms"));
                    delay(5000);
                case 1:
                    Serial.println(F("bad position"));
                case 2:
                    Serial.println(F("bad BMP ID"));
                case 3:
                    Serial.println(F("wrong number of planes"));
                case 4:
                    Serial.println(F("unsupported BMP format"));
                case 5:
                    Serial.println(F("unsupported palette"));
                default:
                    Serial.println(F("unknown"));
    else root.rewindDirectory();
#define BMPIMAGEOFFSET 54
#define BUFFPIXEL      20
uint16_t read16(File& f) {
    uint16_t result;         // read little-endian
    f.read((uint8_t*)&result, sizeof(result));
    return result;
uint32_t read32(File& f) {
    uint32_t result;
    return result;
uint8_t showBMP(char *nm, int x, int y)
    File bmpFile;
    int bmpWidth, bmpHeight;    // W+H in pixels
    uint8_t bmpDepth;           // Bit depth (currently must be 24, 16, 8, 4, 1)
    uint32_t bmpImageoffset;    // Start of image data in file
    uint32_t rowSize;           // Not always = bmpWidth; may have padding
    uint8_t sdbuffer[3 * BUFFPIXEL];    // pixel in buffer (R+G+B per pixel)
    uint16_t lcdbuffer[(1 << PALETTEDEPTH) + BUFFPIXEL], *palette = NULL;
    uint8_t bitmask, bitshift;
    boolean flip = true;        // BMP is stored bottom-to-top
    int w, h, row, col, lcdbufsiz = (1 << PALETTEDEPTH) + BUFFPIXEL, buffidx;
    uint32_t pos;               // seek position
    boolean is565 = false;      //
    uint16_t bmpID;
    uint16_t n;                 // blocks read
    uint8_t ret;
    if ((x >= tft.width()) || (y >= tft.height()))
        return 1;               // off screen
    bmpFile = SD.open(nm);      // Parse BMP header
    bmpID = read16(bmpFile);    // BMP signature
    (void) read32(bmpFile);     // Read & ignore file size
    (void) read32(bmpFile);     // Read & ignore creator bytes
    bmpImageoffset = read32(bmpFile);       // Start of image data
    (void) read32(bmpFile);     // Read & ignore DIB header size
    bmpWidth = read32(bmpFile);
    bmpHeight = read32(bmpFile);
    n = read16(bmpFile);        // # planes -- must be '1'
    bmpDepth = read16(bmpFile); // bits per pixel
    pos = read32(bmpFile);      // format
    if (bmpID != 0x4D42) ret = 2; // bad ID
    else if (n != 1) ret = 3;   // too many planes
    else if (pos != 0 && pos != 3) ret = 4; // format: 0 = uncompressed, 3 = 565
    else if (bmpDepth < 16 && bmpDepth > PALETTEDEPTH) ret = 5; // palette
    else {
        bool first = true;
        is565 = (pos == 3);               // ?already in 16-bit format
        // BMP rows are padded (if needed) to 4-byte boundary
        rowSize = (bmpWidth * bmpDepth / 8 + 3) & ~3;
        if (bmpHeight < 0) {              // If negative, image is in top-down order.
            bmpHeight = -bmpHeight;
            flip = false;
        w = bmpWidth;
        h = bmpHeight;
        if ((x + w) >= tft.width())       // Crop area to be loaded
            w = tft.width() - x;
        if ((y + h) >= tft.height())      //
            h = tft.height() - y;
        if (bmpDepth <= PALETTEDEPTH) {   // these modes have separate palette
            //bmpFile.seek(BMPIMAGEOFFSET); //palette is always @ 54
            bmpFile.seek(bmpImageoffset - (4<<bmpDepth)); //54 for regular, diff for colorsimportant
            bitmask = 0xFF;
            if (bmpDepth < 8)
                bitmask >>= bmpDepth;
            bitshift = 8 - bmpDepth;
            n = 1 << bmpDepth;
            lcdbufsiz -= n;
            palette = lcdbuffer + lcdbufsiz;
            for (col = 0; col < n; col++) {
                pos = read32(bmpFile);    //map palette to 5-6-5
                palette[col] = ((pos & 0x0000F8) >> 3) | ((pos & 0x00FC00) >> 5) | ((pos & 0xF80000) >> 8);
        // Set TFT address window to clipped image bounds
        tft.setAddrWindow(x, y, x + w - 1, y + h - 1);
        for (row = 0; row < h; row++) { // For each scanline...
            // Seek to start of scan line.  It might seem labor-
            // intensive to be doing this on every line, but this
            // method covers a lot of gritty details like cropping
            // and scanline padding.  Also, the seek only takes
            // place if the file position actually needs to change
            // (avoids a lot of cluster math in SD library).
            uint8_t r, g, b, *sdptr;
            int lcdidx, lcdleft;
            if (flip)   // Bitmap is stored bottom-to-top order (normal BMP)
                pos = bmpImageoffset + (bmpHeight - 1 - row) * rowSize;
            else        // Bitmap is stored top-to-bottom
                pos = bmpImageoffset + row * rowSize;
            if (bmpFile.position() != pos) { // Need seek?
                bmpFile.seek(pos);
                buffidx = sizeof(sdbuffer); // Force buffer reload
            for (col = 0; col < w; ) {  //pixels in row
                lcdleft = w - col;
                if (lcdleft > lcdbufsiz) lcdleft = lcdbufsiz;
                for (lcdidx = 0; lcdidx < lcdleft; lcdidx++) { // buffer at a time
                    uint16_t color;
                    // Time to read more pixel data?
                    if (buffidx >= sizeof(sdbuffer)) { // Indeed
                        bmpFile.read(sdbuffer, sizeof(sdbuffer));
                        buffidx = 0; // Set index to beginning
                        r = 0;
                    switch (bmpDepth) {          // Convert pixel from BMP to TFT format
                        case 32:
                        case 24:
                            b = sdbuffer[buffidx++];
                            g = sdbuffer[buffidx++];
                            r = sdbuffer[buffidx++];
                            if (bmpDepth == 32) buffidx++; //ignore ALPHA
                            color = tft.color565(r, g, b);
                        case 16:
                            if (is565)
                                color = (r << 8) | (b);
                                color = (r << 9) | ((b & 0xE0) << 1) | (b & 0x1F);
                        case 1:
                        case 4:
                        case 8:
                            if (r == 0)
                                b = sdbuffer[buffidx++], r = 8;
                            color = palette[(b >> bitshift) & bitmask];
                            r -= bmpDepth;
                            b <<= bmpDepth;
                    lcdbuffer[lcdidx] = color;
                tft.pushColors(lcdbuffer, lcdidx, first);
                first = false;
                col += lcdidx;
            }           // end cols
        }               // end rows
        tft.setAddrWindow(0, 0, tft.width() - 1, tft.height() - 1); //restore full screen
        ret = 0;        // good render
    bmpFile.close();
    return (ret);
When you compile it,what does the monitor show?
The compiling and uploading is fine. I placed serial.println statement to check the program flow .
The program gets stuck after the file f=root:openNextFile or it skips the code and starts running sim800L gprs code.
But showbmp program runs fine .
TFTmonitor
I am getting show BMP files but no image
What does the monitor say after you compile?
Sketch uses 36754 bytes (14%) of program storage space. Maximum is 253952 bytes.
Global variables use 1582 bytes (19%) of dynamic memory, leaving 6610 bytes for local variables. Maximum is 8192 bytes.
Okay. Memory looks good, no space conflict.
