showing error "ultrasonic does not name a type
I have used this code downloaded from internet and it show this error "ultrasonic does not name a type"when trying to upload the code.how to fix this?
// Example program for Arduino 2WD robot
// The robot goes forward until an object is reconised.
// Stop and looks around, left and right and selects the bigger free direction
// That's all...
#include "Ultrasonic.h"
 Ultrasonic ultrasonic(12,13); // init ultrasonic sensor pin 12=trigger, pin13=Echo
 #include <Servo.h>  // include servo functions
 Servo myservo;
// define Motor control pins
#define MotIN1  2
#define MotIN2  4
#define MotIN3  5
#define MotIN4  7
#define MotApwm 3 //PWM output to set the motor speed
#define MotBpwm 6 //PWM output to set the motor speed
// define direction
#define GO  0
#define RIGHT 1
#define LEFT  2
#define BACK  3
#define STOP  4
#define  sMiddle 95
#define  sLeft 0
#define  sRight 165
// *** variables
int CMM;  //ultrasonic sensor distance values
int distL; //distance variable for left direction
int distR;
int SpeedA=200; // motor speed variable, 255=max
int SpeedB=200;
// Setup
  // initialize the digital pin as an output.
  pinMode(MotIN1, OUTPUT);
  pinMode(MotIN2, OUTPUT);
  pinMode(MotIN3, OUTPUT);
  pinMode(MotIN4, OUTPUT);
  pinMode(MotApwm, OUTPUT);
  pinMode(MotBpwm, OUTPUT);
  analogWrite(MotApwm, 200);  //set motor PWM to 200
  analogWrite(MotBpwm, 200);
  myservo.attach(10);  // servo control at pin 10
// ****** Function to set the motor driver lines ***
void setlines( int line1, int line2, int line3, int line4)
  digitalWrite(MotIN1, line1);
  digitalWrite(MotIN2, line2);
  digitalWrite(MotIN3, line3);
  digitalWrite(MotIN4, line4);
//******* Function to set robot direction
void robotdir(int dir)
switch(dir)
case 0:    //GO
  setlines(HIGH, LOW, LOW, HIGH);
case 1:    //Right
  setlines(LOW, HIGH, LOW, HIGH);
case 2:    //Left
   setlines(HIGH, LOW, HIGH, LOW);
case 3:    //Back
   setlines(LOW, HIGH, HIGH, LOW);
case 4:    //Stop
  setlines(LOW, LOW, LOW, LOW);
// **** Measuring distance at given position, and wait for servo setting
int MeasDistInPos(int servpos,int waitime)
  int result;
  myservo.write(servpos);
  delay(waitime);
  result=ultrasonic.Ranging(CM);
  return result;
//************* TURN  ***********************
void Turn(int turndir)
  robotdir(turndir);
  analogWrite(MotApwm, 200); // the turning speed is lower
  myservo.write(sMiddle);
  robotdir(STOP);
//******************* MAIN LOOP **********************
// the loop routine runs over and over again forever:
  CMM = MeasDistInPos(sMiddle,50);
  if (CMM > 30)
    robotdir(GO);
    analogWrite(MotApwm, 250); // tune  2 motors to run straight ahead
    analogWrite(MotBpwm, 245);
    analogWrite(MotApwm, 150);
    analogWrite(MotBpwm, 150);
    robotdir(BACK); // brake with a short opposite direction
    delay(150);
    robotdir(STOP);
    distR=MeasDistInPos(20,500); //look around left and right
    distL=MeasDistInPos(170,500);
   if (distL > distR) // select the bigger distance direction
     Turn(LEFT);
     Turn(RIGHT);
Is that the ONLY error? Are you sure you didn't get an error saying "Ultrasonic.h not found"?
If you got no other error it sounds like your copy of Ultrasonic.h doesn't declare a class named "Ultrasonic". Where did you get the Ultrasonic library? The one I found should work fine: https://github.com/JRodrigoTech/Ultrasonic-HC-SR04
Also, unless the library is in the same folder as the sketch, it could be that:
#include <Ultrasonic.h>
is more appropriate
