How do i let my Arduino Uno R3 and the TFT Display, showing GIF Files?
For now i have used the example Program 5 to Slide between 2 Frames of tf an Picture, but i wonder if an GIF would be possible too?
Here is “my” Code, as i said i´m an total beginner and just copied 98% of the example for now and look for help.
#include <Elegoo_GFX.h>
#include <Elegoo_TFTLCD.h>
#include <SD.h>
#include <SPI.h>
#define LCD_CS A3 // Chip Select goes to Analog 3
#define LCD_CD A2 // Command/Data goes to Analog 2
#define LCD_WR A1 // LCD Write goes to Analog 1
#define LCD_RD A0 // LCD Read goes to Analog 0
#define PIN_SD_CS 10 // Elegoo SD shields and modules: pin 10
#define LCD_RESET A4 // Can alternately just connect to Arduino's reset pin
// When using the BREAKOUT BOARD only, use these 8 data lines to the LCD:
// For the Arduino Uno, Duemilanove, Diecimila, etc.:
// D0 connects to digital pin 8 (Notice these are
// D1 connects to digital pin 9 NOT in order!)
// D2 connects to digital pin 2
// D3 connects to digital pin 3
// D4 connects to digital pin 4
// D5 connects to digital pin 5
// D6 connects to digital pin 6
// D7 connects to digital pin 7
// For the Arduino Mega, use digital pins 22 through 29
// (on the 2-row header at the end of the board).
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
Elegoo_TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
#define MAX_BMP 10
#define FILENAME_LEN 20
const int __Gnbmp_height = 320;
const int __Gnbmp_width = 240;
unsigned char __Gnbmp_image_offset = 0;
int __Gnfile_num = 2;
char __Gsbmp_files[5][FILENAME_LEN] =
"nepnep.bmp",
"nepnep2.bmp",
File bmpFile;
#define BUFFPIXEL 60
#define BUFFPIXEL_X3 180
void bmpdraw(File f, int x, int y)
bmpFile.seek(__Gnbmp_image_offset);
uint32_t time = millis();
uint8_t sdbuffer[BUFFPIXEL_X3];
for (int i=0; i< __Gnbmp_height; i++) {
for(int j=0; j<(240/BUFFPIXEL); j++) {
bmpFile.read(sdbuffer, BUFFPIXEL_X3);
uint8_t buffidx = 0;
int offset_x = j*BUFFPIXEL;
unsigned int __color[BUFFPIXEL];
for(int k=0; k<BUFFPIXEL; k++) {
__color[k] = sdbuffer[buffidx+2]>>3;
__color[k] = __color[k]<<6 | (sdbuffer[buffidx+1]>>2);
__color[k] = __color[k]<<5 | (sdbuffer[buffidx+0]>>3);
buffidx += 3;
for (int m = 0; m < BUFFPIXEL; m ++) {
tft.drawPixel(m+offset_x, i,__color[m]);
Serial.print(millis() - time, DEC);
Serial.println(" ms");
boolean bmpReadHeader(File f)
// read header
uint32_t tmp;
uint8_t bmpDepth;
if (read16(f) != 0x4D42) {
// magic bytes missing
return false;
// read file size
tmp = read32(f);
Serial.print("size 0x");
Serial.println(tmp, HEX);
// read and ignore creator bytes
read32(f);
__Gnbmp_image_offset = read32(f);
Serial.print("offset ");
Serial.println(__Gnbmp_image_offset, DEC);
// read DIB header
tmp = read32(f);
Serial.print("header size ");
Serial.println(tmp, DEC);
int bmp_width = read32(f);
int bmp_height = read32(f);
if(bmp_width != __Gnbmp_width || bmp_height != __Gnbmp_height) { // if image is not 320x240, return false
return false;
if (read16(f) != 1)
return false;
bmpDepth = read16(f);
Serial.print("bitdepth ");
Serial.println(bmpDepth, DEC);
if (read32(f) != 0) {
// compression not supported!
return false;
Serial.print("compression ");
return true;
uint16_t read16(File f)
uint16_t d;
uint8_t b;
b = f.read();
d = f.read();
d <<= 8;
d |= b;
return d;
uint32_t read32(File f)
uint32_t d;
uint16_t b;
b = read16(f);
d = read16(f);
d <<= 16;
d |= b;
return d;
void setup(void) {
Serial.println(F("TFT LCD test"));
#ifdef USE_Elegoo_SHIELD_PINOUT
Serial.println(F("Using Elegoo 2.4\" TFT Arduino Shield Pinout"));
#else
Serial.println(F("Using Elegoo 2.4\" TFT Breakout Board Pinout"));
#endif
Serial.print("TFT size is "); Serial.print(tft.width()); Serial.print("x"); Serial.println(tft.height());
tft.reset();
uint16_t identifier = tft.readID();
if(identifier == 0x9325) {
Serial.println(F("Found ILI9325 LCD driver"));
} else if(identifier == 0x9328) {
Serial.println(F("Found ILI9328 LCD driver"));
} else if(identifier == 0x4535) {
Serial.println(F("Found LGDP4535 LCD driver"));
}else if(identifier == 0x7575) {
Serial.println(F("Found HX8347G LCD driver"));
} else if(identifier == 0x9341) {
Serial.println(F("Found ILI9341 LCD driver"));
} else if(identifier == 0x8357) {
Serial.println(F("Found HX8357D LCD driver"));
} else if(identifier==0x0101)
identifier=0x9341;
Serial.println(F("Found 0x9341 LCD driver"));
}else {
Serial.print(F("Unknown LCD driver chip: "));
Serial.println(identifier, HEX);
Serial.println(F("If using the Elegoo 2.8\" TFT Arduino shield, the line:"));
Serial.println(F(" #define USE_Elegoo_SHIELD_PINOUT"));
Serial.println(F("should appear in the library header (Elegoo_TFT.h)."));
Serial.println(F("If using the breakout board, it should NOT be #defined!"));
Serial.println(F("Also if using the breakout, double-check that all wiring"));
Serial.println(F("matches the tutorial."));
identifier=0x9341;
tft.begin(identifier);
tft.fillScreen(BLACK);
pinMode(10, OUTPUT);
if (!SD.begin(10)) {
Serial.println("initialization failed!");
tft.setCursor(0, 0);
tft.setTextColor(WHITE);
tft.setTextSize(1);
tft.println("SD Card Init fail.");
}else
Serial.println("initialization done.");
void loop(void) {
for(unsigned char i=0; i<__Gnfile_num; i++) {
bmpFile = SD.open(__Gsbmp_files[i]);
if (! bmpFile) {
Serial.println("didnt find image");
tft.setTextColor(WHITE); tft.setTextSize(1);
tft.println("didnt find BMPimage");
while (1);
if(! bmpReadHeader(bmpFile)) {
Serial.println("bad bmp");
tft.setTextColor(BLACK); tft.setTextSize(1);
tft.println("bad bmp");
return;
bmpdraw(bmpFile, 0, 0);
bmpFile.close();
