SHT-11 temp sensor with Arduino
Hi Guys,
I'm trying to interface with the SHT-11 digital temperature and humidity sensor. I will note that I have never tried to use SPI before, so I am probably making some gross error!
The data sheet is here: http://www.sensirion.com/en/pdf/product_information/Data_Sheet_humidity_sensor_SHT1x_SHT7x_E.pdf
It uses a 2 wire SPI interface. After I start the transmission (pulsing SCK wile DATA is high) and send the command byte (00000011), the SHT-11 should pull DATA low to acknowledge the transmission.
As you can see, I have a while structure to test if DATA is low, but all I see in the serial monitor is "Still busy" (never seeing 'ready to read data') indicating that DATA is high and not being pulled low. What am I doing wrong?
Could this be a bad IC, or is it me? I would appreciate some help for a newbie!
Tom.
int sckPin = 8;
int dataPin = 9;
int busy = 1;
void shtStart() {
  pinMode(dataPin, OUTPUT);
  dataPin = HIGH;
  sckPin = HIGH;
  dataPin = LOW;
  sckPin = LOW;
  sckPin = HIGH;
  dataPin = HIGH;
  sckPin = LOW;
  dataPin = LOW;
void pulseSck() {
  sckPin = HIGH;
  sckPin = LOW;
  pinMode(sckPin, OUTPUT);
  // Prepare IC to receive command byte
  shtStart();
  // Transmit address (always 000)
  pulseSck();
  pulseSck();
  pulseSck();
  // Transmit temperature command (00011)
  pulseSck();
  pulseSck();
  pulseSck();
  dataPin = HIGH;
  pulseSck();
  pulseSck();
  // Data pin is now an input
  pinMode(dataPin, INPUT);
  // Wait for the IC to pull dataPin LOW
  // indicating that temperature has been
  // measured
  busy = digitalRead(dataPin);
  while(busy == 1) {
    Serial.println("Still busy");
    delay(100);
  Serial.println("Ready to read data");
  delay(10000);
A nice blog-post with SHT-11 code.
