sht15 and atmega 1280-16A
After looking at the sht15 datasheet I know that it uses spi to communicate with the atmega. I'm having trouble interfacing this device because there is no chip select, and I have more than one sensor on the spi pins. Does the sht15 have set addr? 0? If so, what other means could I use to establish communication?
It's some code they pulled out of ...thin air.
http://www.glacialwanderer.com/hobbyrobotics/?p=5
I've not tried it.
Might need to rehydrate it.
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1207363224/15
There is no need to use the spi bus you could just bit bang the communications on any line. You won't be reading it very often (the sensor has a slow response time so there is no point) so it is no great overhead.
Thanks guys makes perfect since now.
