Hey all, Ok I’m off the interfacing. This is more of a code question
I’m using the sht15 and scp1000 the code for pressure works well the sht15 compiles and loads but doesn’t print out anything at com port
here is my code sorry not sure how to do this I got the code from
- copyleft 2007 Wayne Prasek wprasek@gmail.comm
- http://ragingreality.thotbot.com/
int dataPin = 9;
int sckPin = 8;
void resetSHT()
pinMode(dataPin,OUTPUT);
pinMode(sckPin,OUTPUT);
shiftOut(dataPin, sckPin, LSBFIRST, 255);
digitalWrite(dataPin,HIGH);
for(int i = 0; i < 15; i++){
digitalWrite(sckPin, LOW);
digitalWrite(sckPin, HIGH);
//Specific SHT start command
void startSHT()
digitalWrite(sckPin,HIGH);
digitalWrite(dataPin,LOW);
digitalWrite(sckPin,LOW);
void writeByteSHT(byte data)
// digitalWrite(dataPin,LOW);
shiftOut(dataPin,sckPin,MSBFIRST,data);
pinMode(dataPin,INPUT);
//Wait for SHT15 to acknowledge by pulling line low
while(digitalRead(dataPin) == 1);
digitalWrite(sckPin,LOW); //Falling edge of 9th clock
//wait for SHT to release line
while(digitalRead(dataPin) == 0 );
//wait for SHT to pull data line low to signal measurement completion
//This can take up to 210ms for 14 bit measurments
int i = 0;
while(digitalRead(dataPin) == 1 )
i++;
if (i == 255) break;
delay(10);
//debug
i *= 10;
Serial.print("Response time = ");
Serial.println(i);
//Read 16 bits from the SHT sensor
int readByte16SHT()
int cwt = 0;
unsigned int bitmask = 32768;
int temp;
for(int i = 0; i < 17; i++) {
if(i != 8) {
temp = digitalRead(dataPin);
// Serial.print(temp,BIN);
cwt = cwt + bitmask * temp;
bitmask=bitmask/2;
else {
//leave clock high??
// Serial.println();
return cwt;
int getTempSHT()
startSHT();
writeByteSHT(B0000011);
return readByte16SHT();
int getHumidSHT()
startSHT();
writeByteSHT(B00000101);
Serial.begin(9600); // connect to the serial port
Serial.println(“Resetting SHT…”);
resetSHT();
void loop () {
delay(2000);
Serial.println(“Starting Temperature/Humidity reading…”);
int temp = getTempSHT();
Serial.print(“Temprature:”);
Serial.println(temp);
temp = getHumidSHT();
Serial.print(“Humidity:”);
