Hello,
I've a working hardware setup and two codes 1 to read the sht30 and push the data to my tft screen.
And 2 a code to set a fan (2fans) on and off.
I want to combine these whenever the humidity is over 50% the fans should go on.
3 issues arise.
- less important my serial.println() doesn't print anything anymore
- my second if loop doesn't get printed not in serial or in display
- Fans are not getting activated by the code.
My searching leads me to think I need to convert my sht30.humidity into an int before making the if loop.
Or it could be something entirely else ofcourse.
#include <WEMOS_SHT3X.h>
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
Adafruit_SSD1306 display(1);
#if (SSD1306_LCDHEIGHT != 32)
#error("Height incorrect, please fix Adafruit_SSD1306.h!");
#endif
SHT3X sht30(0x45);
pinMode(14, OUTPUT);
// initialize with the I2C addr 0x3C
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
display.display();
Serial.print("start");
// Clear the buffer.
display.clearDisplay();
display.setTextSize(1);
display.setCursor(0, 0);
display.setTextColor(WHITE);
if(sht30.get()==0)
display.setCursor(35, 10);
display.println("T: ");
display.setCursor(50, 10);
display.println(sht30.cTemp);
display.setCursor(35, 20);
display.println("H: ");
display.setCursor(50, 20);
display.println(sht30.humidity);
display.println("Error!");
Serial.println("error");
display.display();
Hcheck();
Serial.println("checking humidity");
void Hcheck() {
delay(5000);
Serial.println("============ Check Humidity ===============");
display.display();
Serial.println(sht30.humidity);
if(sht30.humidity <= 50 ) {
digitalWrite(14, HIGH);
display.display();
}else {
digitalWrite(14, LOW);
Serial.println("Air is dry");
