Address in code is showing 0x44 and 0x60. Any idea what would cause this as the sensor is stating is failing connection? Sensor is connected to Arduino Wifi Rev 2 via the 3.3V pin.
What code would that be ?
The code was working and then stopped. I have tried replacing it with 3 different sensors. All fail.
As I said
Hi @adopted01
Post a schematic of your project.
Did you use pullup resistors for the I2C bus?
RV mineirin
It ended up being loose wires.
