i buy this sensor and i try to connect with Arduino Uno, i have problems with library :
http://playground.arduino.cc/Code/Sensirion
error is: #Include "WConstants.h":
the next step i try this library :
With this example work the sensor but with out Draw Point and Wet Bulb
also i found in the google this model Mastech MS6508 this tool work with SHT75 sensor and this read Wet Bulb. .
Can i read wet bulb and Draw point in Arduino with SHT 75?
The original code is
* ReadSHT1xValues
* Read temperature and humidity values from an SHT1x-series (SHT10,
* SHT11, SHT15) sensor.
* Copyright 2009 Jonathan Oxer <jon@oxer.com.au>
* www.practicalarduino.com
#include <SHT1x.h>
// Specify data and clock connections and instantiate SHT1x object
#define dataPin 10
#define clockPin 11
SHT1x sht1x(dataPin, clockPin);
Serial.begin(9600); // Open serial connection to report values to host
Serial.println("Starting up");
float temp_c;
float temp_f;
float humidity;
// Read values from the sensor
temp_c = sht1x.readTemperatureC();
temp_f = sht1x.readTemperatureF();
humidity = sht1x.readHumidity();
// Print the values to the serial port
Serial.print("Temperature: ");
Serial.print(temp_c, DEC);
Serial.print("C / ");
Serial.print(temp_f, DEC);
Serial.print("F. Humidity: ");
Serial.print(humidity);
Serial.println("%");
delay(2000);
}/code]
