SHT75 serial reading and reading on display
reading the SHT75 with the script from bbrack.net is no problem.
Also I would like to read the Temp, Humidity and the dewpoit on a
serial display.
I added the library LiquidCristal in set up nicely printed temp, hum and dewpoint.
But no data is printed on the display.
Can someone help with this topic.
Theo
Well, you could help yourself a bit by posting your sketch.
Dear Groove,
Indeed it will help to enclose the script.
/* werkt met 3 sturen in serial monitor............
  • en op data port 4 als je die programmeerd en uitleest.
  • dus meerdere SHT zijn aan te sluiten en uit te lezen.
  • This program is an adaptation of the 8051 Sample Program provided
  • by Sensirion. A CRC check, using program calculation, is added,
  • again based upon code suggested by Sensirion.
  • There are several points at which a short delay is required. Although
  • only a few microseconds should be sufficient, in order to assure that
  • we can extend the connection to the SHT75 away from the Arduino, I have
  • defined three constants - SHORT_DELAY, MEDIUM_DELAY and LONG_DELAY - so that
  • one can easily experiment with them to determine reasonable values.
  • Connections:
  • SHT-xxs arduino
  • All SCK pins --- D2
  • All VDD pins --- 3.3V
  • All GND pins --- Gnd
  • 1st SHT's DATA --- D3
  • 2nd SHT's DATA --- D4
  • 3rd SHT's DATA --- D5
  • and more...
#include <ctype.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd(6,7,8,9,10,11,12);
#define DATA 4 /* Arduino pin for data read/write /// aangezet
For multiple SHTs, DATA port is given later /
#define CLOCK 2 /
Arduino pin for toggling the clock */
#define NOACK 0 /* Flags to tell read_byte routine whether /
#define ACK 1 /
or not to send an ACK after the read /
#define ledPin 13 /
toegevoegd om te schakelen.
/* Define the SHT1x commands to be their command codes */
#define MEASURE_TEMP 0x03
#define MEASURE_HUMI 0x05
#define STATUS_REG_W 0x06
#define STATUS_REG_R 0x07
#define RESET 0x1e
/* Following constants are in microseconds */
#define LONG_DELAY delayMicroseconds(80)
#define MEDIUM_DELAY delayMicroseconds(40)
#define SHORT_DELAY delayMicroseconds(20)
unsigned char debug; /* When set, intermediate data is printed */
  • sWriteByte
  • Routine to write a byte to the SHT75 and check for the acknowledge
  • Parameters:
  • @value byte value to be written
  • @dataport data port to access
  • Returns:
  • 0 for success, 1 if no Acknowledge received from SHT1x
    char sWriteByte(unsigned char value, unsigned int dataport)
    unsigned char ix; /
    loop index /
    unsigned char error; /
    result of the write */
pinMode (dataport, OUTPUT);
for (ix = 0x80; ix; ix >>= 1) {
digitalWrite (dataport, ix & value);/* Next bit to I/O port /
SHORT_DELAY; /
Shouldn't be needed /
digitalWrite (CLOCK, HIGH); /
Set clock signal high /
MEDIUM_DELAY; /
some delay needed /
digitalWrite (CLOCK, LOW); /
Set clock back to low /
pinMode (dataport, INPUT); /
Prepare to read the ACK bit /
digitalWrite (dataport, HIGH); /
Engage pull-up resistor /
Send 9th clock for ack) /
//SHORT_DELAY;
MEDIUM_DELAY;
error = digitalRead (dataport); /
Expect pulled down by SHT1x /
SHORT_DELAY;
complete the clock pulse */
return error;
  • sReadByte
  • Routine to read one byte from the SHT75. An acknowledge may or
  • may not be generated, according to the routine's argument.
  • Parameters:
  • @sendAck If non-zero, an ACK is sent to the SHT1x if
  • the read was successful.
  • Returns:
  • The value read from the SHT1x
    char sReadByte (unsigned char sendAck, unsigned int dataport)
    unsigned char ix; /
    loop index /
    unsigned char val = 0; /
    for building the received data */
  • Note to Bill: we should assure DATA is input by default
  • and get rid of these next two lines
    Set data pin for input mode /
    Engage pull-up resistor */
digitalWrite (CLOCK, HIGH); /* High tells SHT75 we're reading /
SHORT_DELAY;
if (digitalRead (dataport))
val |= ix; /
If DATA high, set corr. bit /
Tell SHT75 ready for next bit /
SHORT_DELAY;
pinMode (dataport, OUTPUT); /
Change mode to prepare for ack /
digitalWrite (dataport, !sendAck); /
Set DATA LOW if sendAck requested /
Let SHT75 get the data /
MEDIUM_DELAY; /
delay for safety /
Signal we're done with this /
SHORT_DELAY;
Return Arduino pin to input /
And engage the pull-up */
return val;
  • sTransmitStart
  • Routine to generate a "Transmission Start", which looks like:
  • DATA: |_________|
  • CLOCK: _____| || |
  • Parameters:
  • Returns:
  • No return value.
    void sTransmitStart (unsigned int dataport)
    Set DATA mode output /
    Start DATA in high state */
    SHORT_DELAY;
    SHORT_DELAY;
    digitalWrite (dataport, LOW);
    SHORT_DELAY;
    MEDIUM_DELAY;
    SHORT_DELAY;
    SHORT_DELAY;
    SHORT_DELAY;
  • sConnectionReset
  • Routine to generate a transmission reset, i.e. reset the SHT1x
  • to a known state to begin a transmission. It produces a pulse
  • train that looks like this:
  • DATA: |_______|
  • SCK : | || || || || || || || || || || |__
  • Parameters:
  • Returns:
  • No return value.
    void sConnectionReset (unsigned int dataport)
    unsigned char ix;
    Set Data to output mode /
    Start Data in high state /
    Start Clock in low state /
    Now generate 9 clock "pulses" /
    for (ix = 0; ix < 9; ix++) {
    MEDIUM_DELAY;
    MEDIUM_DELAY;
    sTransmitStart (dataport); /
    Follow with start pulse */
  • sSoftReset
  • Routine to do a "soft" reset, i.e. send a "Reset" command to the SHT75
  • Parameters:
  • Returns:
  • 0 for success, 1 if bad response from SHT75
    char sSoftReset (unsigned int dataport)
    sConnectionReset (dataport); /
    Reset SHT75 communication /
    return sWriteByte (RESET, dataport); /
    Send command and return result */
  • doCRC
  • Routine to calculate the CRC while message is sent / received
  • Parameters:
  • @ch character to be added to CRC
  • @crc crc to which character is to be added
  • Returns:
  • Target CRC value is updated
    #define CRC_POLY 0x31 /
    CRC polynomial x8 + x5 + x**4 */
    void doCRC (unsigned char ch, unsigned char *crc)
    int ix;
    unsigned char b7;
for (ix = 0; ix < 8; ix++) {
b7 = ch ^ *crc;
*crc <<= 1;
ch <<= 1;
if (b7 & 0x80)
*crc ^= CRC_POLY;
return;
  • sMeasure
  • Routine to make a measurement of either temperature or humidity, and
  • return the result.
  • Parameters:
  • @pValue pointer to where value should be stored
  • @command command to be sent to the SHT1x
  • @singleFlag Flag to show a single byte only should be read
  • Returns:
  • Returns the status from the 'read' of the data, and places the value
  • read into the the locations pointed at by the arguments. Note that the
  • SHT1x returns data as (MSB, LSB) so this routine stores the
  • (short integer) value in reverse seque
Dear Groove,
As the script is to large for one post i have to post it at maybe three posts.
sec. one
char sMeasure (unsigned char pValue, unsigned char command,
unsigned char singleFlag, unsigned int dataport)
holds return value from routine /
unsigned int ix; /
used for 'wait for data' loop */
unsigned char ch, crc, revCRC;
crc = 0; /* Initialize CRC to zero /
Start transmission of command /
error = sWriteByte (command, dataport); /
Send the requested command /
Note that sWriteByte leaves DATA in input mode /
doCRC (command, &crc); /
Include command in CRC /
if (debug) {
Serial.print("After 'command': CRC is 0x");
Serial.println(crc, HEX);
for (ix = 0; ix < 240; ix++){
delay(1); /
This delay is needed for long cables /
if (!digitalRead (dataport))
Serial.println("DATA did not go low after writing command");
if (!singleFlag) { /
If a 2-byte reply /
ch = sReadByte (ACK, dataport); /
Read MSB of data /
doCRC (ch, &crc); /
Include in CRC */
if (debug) {
Serial.print("After MSB: CRC is 0x");
(pValue + 1) = ch; / Store MSB byte /
Read LSB of data /
doCRC (ch, &crc); /
Include in CRC */
pValue = ch; / Store LSB byte /
if (debug) {
Serial.print("After LSB: CRC is 0x");
ch = sReadByte (NOACK, dataport); /
Read msg CRC, don't send ACK */
revCRC = 0;
if ((0x80 >> ix) & ch)
revCRC |= (1 << ix);
if (debug) {
Serial.print("After Checksum: CRC is 0x");
Serial.print(crc, HEX);
Serial.print(", received value was 0x");
Serial.println(revCRC, HEX);
if (crc != revCRC) {
Serial.print("CRC error in reply (command was 0x");
Serial.print(command, HEX);
Serial.print("CRC is 0x");
Serial.println(") - resetting SHT1x connection");
sConnectionReset(dataport);
return error;
  • calcTempHumid
  • Routine to calculate the "true" temperature and humidity based upon
  • the "tick" values read from the SHT1x. The SHT1x is set to operate in
  • 12-bit mode for humidity, and 14-bit mode for temperature. The
  • conversion constants are taken from the SHT1x datasheet, assuming a
  • supply voltage of 5.0V.
  • Parameters:
  • @pHumidity pointer to humidity value
  • @pTemperature pointer to temperature value
  • Returns:
  • Input values of temperature and humidity are overwritten with their
  • calculated "true" values.
    void calcTempHumid (float *pHumidity, float pTemperature)
    Constants for conversion of reading to relative humidity /
    #define C1 -4.0
    #define C2 +0.0405
    #define C3 -0.0000028
    Constants for temperature-compensated relative humidity /
    #define T1 +0.01
    #define T2 +0.00008
    Constants for conversion of temperature reading to Centigrade */
    //#define D1 -40.10 //5.0V operation
    #define D1 -39.651 //3.3V operation
    #define D2 +0.01
float rh = pHumidity; / relative humidity (input value) /
float rhLin; /
Linear value of humidity /
float rhTrue; /
Temperature-compensated humidity value */
float t = pTemperature; / input value for temperature /
float tC; /
Temperature converted to Celsius */
tC = D1 + (t * D2); /* Linear conversion of temperature /
rhLin = (C3 * rh * rh) + (C2 * rh) + C1; /
"ticks" to relative H /
rhTrue = (tC - 25) * (T1 + (T2 * rh)) + rhLin;
Assure our relative humidity isn't out of range (> 100% or < 0.1%) /
if (rhTrue > 100.0)
rhTrue = 100.0;
else if (rhTrue < 0.1)
rhTrue = 0.1;
Finally, return the calculated values */
*pTemperature = tC;
*pHumidity = rhTrue;
  • calcDewPoint
  • Routine to calculate the dew point based upon relative humidity
  • and temperature. I have no idea what it's doing, but since it
  • comes from the Sensirion literature, it's probably correct :-).
  • Parameters:
  • @humidity value of relative humidity
  • @temperature value of temperature
  • Returns:
  • Calculated dew point
    float calcDewPoint (float humidity, float temperature)
    float logEx;
    logEx = 0.66077 + (7.5 * temperature) / (237.3 + temperature)
  • (log10(humidity) - 2);
    return (logEx - 0.66077) * 237.3 / (0.66077 + 7.5 - logEx);
  • splitFloat
  • This routine takes a float as input and returns the integer part and
  • the fractional part, to the number of decimal places specified. The
  • only reason I wrote it is because I couldn't find any existing routine
  • to print out a float in a reasonable format (with decimal places)
  • Parameters:
  • @fNum The floating point number to be dissected
  • @pInt Pointer to an integer to contain the integer part
  • @pFrac Pointer to a string to contain the fraction
  • Note: the caller must assure the string is large enough
  • @decPlaces Number of decimal places for the operation
  • Returns:
  • The values calculated are placed in the locations specified.
    void splitFloat (float *fNum, int *pInt, char *pFrac, int decPlaces) {
int ix;
int frac;
float fVal;
/* Round the input according to precision, plus fudge for noise */
fVal = *fNum + (0.5 * pow(10.0, (float)(-decPlaces))) + 0.00001;
pInt = fVal; / Return truncated integer value /
  • Now isolate just the fractional part of the original number
    fVal = fVal - (float)(pInt); / Remove the integral part /
    Convert the fraction into a simple integer /
    frac = fVal * pow (10.0, (float)decPlaces);
    Now format it as a leading-zero string of digits /
    pFrac += decPlaces; /
    point to string terminator position */
    pFrac-- = 0; / put in terminator */
    for (ix = 0; ix < decPlaces; ix++) {
    pFrac-- = (frac % 10) | 0x30; / put in digits in reverse order */
    frac /= 10;
  • printReading
  • Routine to print out the value of caculated data, using a common format
  • of {label} {int value}.{single digit fraction}{suffix}
  • Parameters:
  • @label string for starting label
  • @pVal pointer to float value to display
  • @suffix string to append to value
  • Returns:
  • nothing
    void printReading (char *label, float *pVal, char *suffix) {
    int num;
    char str[10];
splitFloat (pVal, &num, str, 2);
Serial.print(label);
Serial.print(num, DEC);
Serial.print(".");
Serial.print(str);
Serial.println(suffix);
  • setup
  • This is the routine required by the Arduino software to initialize
  • anything needed by the main loop. We set up the DATA and CLOCK ports
  • to a beginning state.
    int fTemperature;
    lcd.begin(4,16); // LCD rows and colomns
    // lcd.init();
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print("Temperatuur:");
    lcd.setCursor(0,1);
    // 1234567890
    lcd.print("Vochtigheid:");
    lcd.setCursor(-4,2);
    // 1234567890
    lcd.print("Dauwpunt:");
    lcd.setCursor(-4,3);
    lcd.print("Testprint:");
Serial.begin(4800); /* Open Arduino serial communications was 9600 veranderd dus */
pinMode (CLOCK, OUTPUT);
pinMode (DATA, OUTPUT); // aan gezet
for (int i = 3; i < 10; i++){
sConnectionReset(i);
Serial.println("Acceptable commands:");
Serial.println("d or D: Toggle debug flag for printing intermediate data");
Serial.println("s or S: Read status register");
Serial.println("3 - 9 : Read in temperature and humidity\n");
char cmd; /* command input by user /
int humidVal; /
humidity value read from SHT75 /
int tempVal; /
temperature value from SHT75 /
unsigned char statusVal; /
contents of status register /
float fHumidity; /
working value for humidity calculation /
float fTemperature; /
working value for temperature calculation /
float dewPoint; /
calculated Dew Point value /
return value for routi
Dear Grooove,
It will do in three posts.
the third one.
More explanation:
I already added the LiquidDisplay library.
Programmed the tempereture:
Vochtigheid:
Dewpoint:
So far ok. But if i am program lcd.print (fTemperature,DEC); it will not apear on the display. However the ledpin is working on fTemperature.
What I would like to achieve is real time reading temp, hum, and dewp on the display.
unsigned int port;
while (Serial.available() > 0) { /* when a serial connection exists /
cmd = Serial.read(); /
Read user comand /
error = 0;
if (isdigit(cmd)) {
port = atoi(&cmd);
if (port < 2) {
Serial.println("Unable to access serial communication port!\n");
if (port == CLOCK) {
Serial.println("Unable to access SHT-xx CLOCK port!\n");
Read request - read in temperature and humidity */
Serial.print("Accessing port ");
Serial.println(port);
error += sMeasure ((unsigned char *)&humidVal, MEASURE_HUMI, 0, port);
if (debug) {
Serial.print("In main loop: humidVal is ");
Serial.print(humidVal, HEX);
Serial.print(" and return value is ");
Serial.println(error, DEC);
error += sMeasure ((unsigned char *)&tempVal, MEASURE_TEMP, 0, port);
if (debug) {
Serial.print("In main loop: tempVal is ");
Serial.print(tempVal, HEX);
if (error)
sConnectionReset(port);
else {
fHumidity = float(humidVal);
fTemperature = float(tempVal);
calcTempHumid (&fHumidity, &fTemperature);
dewPoint = calcDewPoint (fHumidity, fTemperature);
//printReading ("Temperature is ", &fTemperature, "\xb0 Celsius");
printReading ("Temperatuur is ", &fTemperature, " degrees Celsius");
printReading ("Vochtigheid is ", &fHumidity, "%");
//printReading ("Dauw punt is ", &dewPoint, "\xb0 Celsius");
printReading ("Dauw punt is ", &dewPoint, " degrees Celsius");
if (fTemperature > 20.89) { // toegevoegd om te schakelen
digitalWrite ( ledPin,HIGH);
}else{
digitalWrite( ledPin,LOW); // toegevoegd om te schakelen
switch (cmd) {
case 'd': /* "Toggle" debug flag for printing /
case 'D': /
intermediate data /
debug ^= 1;
if (debug)
Serial.println("
*** Debugging enabled ");
Serial.println("
Debugging disabled ***");
case 's': /
Read status register /
case 'S':
Serial.println("Read status register. Input a port number:");
while(1) {
Read user comand /
if (isdigit(cmd)) {
port = atoi(&cmd);
if (port < 2) {
Serial.println("Unable to access Serial port!\n");
Serial.println("Unable to access CLOCK port!\n");
error += sMeasure ((unsigned char *)&statusVal, STATUS_REG_R, 1, port);
Serial.print("Status register contains 0x");
Serial.println(statusVal, HEX);
default:
Serial.println("Unrecognized command.");
For those who are interrested in reading sht data serial as well as on LCD here my code for the LCD part.
First include the liquidCrystal.h lib in your script.
Then the LCD i/o pins
I introduced a selector switch serial or LCD
If LCD use the code
}else{
port=5; // leest de data uit ARDUINO data port
digitalWrite(lcdLed,HIGH); // keuze switch op lcd als led aan is.
sMeasure ((unsigned char *)&tempVal, MEASURE_TEMP, 0, port); // leest de temp waarde grof uit de SHT
sMeasure ((unsigned char *)&humidVal, MEASURE_HUMI, 0, port); // pas op op deze stand warmt sht op kennelijk door verwarming calibratie.??????????
fTemperature = float(tempVal); // ruwe SHT temp waarde omzetten naar float
Temperature=(fTemperature/100)-40,561; // ruwe waarde naar werkelijke waarde omrekenen.
fHumidity = float(humidVal); // ruwe SHT humid waarde omzetten naar float
Humidity=(((fHumidity * fHumidity * -28) / 10000000)+((fHumidity * 4)/100))-4; // ruwe waarde omrekenen naar werkelijke waarde
logEx = 0.66077 + (7.5 * Temperature) / (237.3 + Temperature) + (log10(Humidity) - 2); // dauw punt berekenen uit temp en humid.
Dauwpunt= (logEx - 0.66077) * 237.3 / (0.66077 + 7.5 - logEx);
lcd.setCursor(9,0); // print to lCD
lcd.print(Temperature);
lcd.setCursor(9,1);
lcd.print(Humidity);
lcd.setCursor(6,2);
lcd.print(Dauwpunt);
lcd.setCursor(6,3);
lcd.print("on LCD");
if (Temperature < 18.89) { // toegevoegd om te schakelen
}else{
} :slight_smile:
Hopefully it is of interesr for someone.
Theo
Misschien een idee om je posts te veranderen (rechts van je post "modify") door # te gebruiken.
Selecteer je code en klik op #. Het word niet op prijs gesteld om code zo te posten. :slight_smile:
Jeroen
hinted the use of #
Note to solution reading also on display.
After you read the measurements on port #5
you must switch off port #5 again and delay a moment.
All according the SHT data sheet point 3 while continous power on gives incorrect readings.
Theo
Jeroen,
Bedankt voor de tip.
Ik heb vlug even de help gelezen en er is veel
te doen om een juiste post te maken plaatsen.
Theo
