I have several 4 types of "nrf24l01+" modules:
(1) with antenna connector and external antenna
(2) green "small one" wich nrf24l01+ chip
(3) black "small one" with si24r1 chip
(4) black "small one" with nrf24l01+ chip
Until now I used setup:
(1) as receiving module - collecting data from 3 wireless transceivers
(2)+(3)+(3) as transceivers
Everything worked perfectly - I had results when I could transmit over 3-4 walls from bricks (over whole my apartment).
But recently I wanted to add some nodes, so I bought couple of additional nrf24l01+ modules (4) and noticed they work (exactly the same sketch, exactly the same arduino setup) only with very short distances. I can't get them work with larger distances like I used to have with the old modules. I also tried direct replacing the "old" module with this "new" one on the same board and it confirmed me the new modules (4) simply do not work on longer distances.
Interesting is that the working modules (2)+(3) are marked as 24l01+ and si24r1 - so one is most likely original and one is a clone. Both worksfine. This new one (4) is marked as 24l01+, so most likely an original?
Did anybody encountered such huge difference between sensitivity(quality) of the nrf24l01+ modules? Photos of my modules are attached.
