SI4432 Help
Hey guys, I'm new to arduino and i'd like some help about the SI4432 wireless modules. I read online that the library i was supposed to use is RF22 and when i use this library with the rf22_test example it says init failed :/
Do you have any idea what is wrong ?
I tested it on uno without the CD4050 and it doesn't seem to work, and the second time i tried on a Pro Mini 3v3 8Mhz which did not work either :'(
I used this : http://www.electrodragon.com/w/SI4432_433M-Wireless_Transceiver_Module_%281.5KM_Range,_Shield-Protected%29
And the module is one I bought off ebay .
Thx !
Module is 3.3V, interfacing it directly to 5V arduino is a way to kill. Does your board looks like this: http://coolarduino.blogspot.ca/2015/09/rf-scanner.html
Thanks for the answer! But before i hooked it up to 5v arduino i hooked it up to 3v3 Pro mini and it didn't work :/ If you have any other advice I still have a second module to try out.
And yes it is the same as in the picture but with green soldermask insted of blue ;)
Hello, I bought this module, and I linked it to arduino pro mini at 3.3v. I hope I linked it correctly, anyone has a wiring diagram to share? Also, it's possibile to receive a 433mhz coming from a remote control to turn-on a lamp (after arduino linked to a relay)? And how to do this?
Thankyou
Cisbot
