SI5351 Sketch with display question
I am using this SI5351 code with an oled display. The oled display lets me know what frequency the SI5351 clock generator is outputting. What im wanting to do is make the display give me the value after a simple math equation.
for example in the code it will give me 12.650.000 Mhz, but I would like it to display 12.650.000 * 36 which would give me 455.400. the 455.400 is what I want to be on the display. The rotary encoder allows me to change frequency. I am just wanting the display to give me the result of whatever frequency the SI5351 is outputting and times it by 36. Any help would be appreciated.
   It is a multipurpose signal generator controlled by Arduino. This project uses the SI5351 from Silicon Labs.
   This sketch is configured to control the SI5351 from 32.768KHz to 160MHz and steps from 1Hz to 1MHz.
   With this sketch you can control the three clock outputs.
   For SI5351 control, this sketch uses the the Etherkit/si5351 Arduino library from Jason Milldrum (https://github.com/etherkit/Si5351Arduino);
   For encoder control, this sketch uses the Rotary Encoder Class implementation from Ben Buxton (the source code is included together with this sketch)
   Arduino Pro Mini 3.3V (8MHz) and SI5351 breakout wire up
   | Device name        | Device Pin / Description  |  Arduino Pin  |
   |   OLED             |                           |               |
   |                    | SDA                       |     A4        |
   |                    | SCL                       |     A5        |
   |   SI5351           |                           |               |
   |                    | SDIO (pin 18)             |     A4        |
   |                    | SCLK (pin 17)             |     A5        |
   |   Buttons          |                           |               |
   |                    | SWITCH_CMD                |      4        |
   |                    | BUTTON_UP                 |      6        |
   |                    | BUTTON_DOWN               |      5        |
   |   Encoder          |                           |               |
   |                    | A                         |      3        |
   |                    | B                         |      2        |
   See https://github.com/etherkit/Si5351Arduino  and know how to calibrate your Si5351
   Author: Ricardo Lima Caratti 2020
#include <si5351.h>
#include <Wire.h>
#include "Rotary.h"
#include "SSD1306Ascii.h"
#include "SSD1306AsciiAvrI2c.h"
// Enconder PINs
#define ENCODER_PIN_A 3 // Encoder pin A
#define ENCODER_PIN_B 2 // Encoder pin B
#define SWITCH_CMD  4   // ENCODER button or regular push button
#define BUTTON_UP   6   // Button up command
#define BUTTON_DOWN 5   // Button down command
#define CMD_STEP     0
#define CMD_FAVORITE 1
#define CMD_CLK      2
// OLED Diaplay constants
#define I2C_ADDRESS 0x3C
#define RST_PIN -1 // Define proper RST_PIN if required.
// Change this value bellow  (CORRECTION_FACTOR) to 0 if you do not know the correction factor of your Si5351A.
//#define CORRECTION_FACTOR -13500 // See how to calibrate your Si5351A (0 if you do not want).
 #define CORRECTION_FACTOR 160300
#define MIN_VFO 3276800LLU
#define MAX_VFO 16000000000LLU    // VFO max. frequency 30MHz
// Struct for step
typedef struct
  char *name; // step label: 50Hz, 10Hz, 500Hz and 100KHz
  long value; // Frequency value (unit 0.01Hz See documentation) to increment or decrement
} Step;
// Steps database. You can change the Steps and numbers of steps here if you need.
Step step[] = {
    {(char *)"1Hz", 100},   // Minimum Frequency step (incremente or decrement) 1Hz
    //{(char *)"10Hz", 1000},
    {(char *)"100Hz", 10000},
    //{(char *)"500Hz", 50000},
    {(char *)"1KHz", 100000},
    //{(char *)"5KHz", 500000},
    {(char *)"10KHz", 1000000},
    //{(char *)"32.768K", 3276800},
    //{(char *)"50KHz", 5000000},
    {(char *)"500KHz", 50000000},
    {(char *)"1MHz", 100000000}}; // Maximum frequency step 500KHz
// Calculate the index of last position of step[] array
const int lastStepVFO = (sizeof step / sizeof(Step)) - 1;
int currentStep = 4;
// Your favotite frequencies
uint64_t favorite[] = {3276800LLU, 350000000LLU, 710000000LLU, 1293320000LLU, 1070000000LLU, 1200000000LLU,
                       1350000000LLU, 1600000000LLU, 2000000000LLU, 2400000000LLU, 2700000000LLU, 2800000000LLU,
                       3200000000LLU,4600000000LLU, 5000000000LLU, 10000000000LLU, 13300000000LLU, 14400000000LLU};
const int lastFavorite = (sizeof favorite / sizeof(uint64_t) ) - 1;
int currentFavorite = 3;
uint64_t currentOutputClock[]{1070000000LLU, 1350000000LLU, 3276800LLU}; // Stores the current clock on CLK0, CLK1 and CLK2
const int lastCurrentOutputClock = (sizeof currentOutputClock / sizeof(uint64_t)) - 1;
int currentClock = 0; // current clock output 0
int currentCommand = CMD_STEP;
char *cmd[] = {(char *) "Step", (char *) "Favorite", (char *) "Out. Clk" };
char *clk[] = {(char *) "CLK0", (char *) "CLK1", (char *) "CLK2" };
// Encoder controller
Rotary encoder = Rotary(ENCODER_PIN_A, ENCODER_PIN_B);
// OLED - Declaration for a SSD1306 display connected to I2C (SDA, SCL pins)
SSD1306AsciiAvrI2c display;
// The Si5351 instance.
Si5351 si5351;
bool isFreqChanged = true;
bool clearDisplay = false;
uint64_t vfoFreq;
uint64_t vfoLastValue;
// Encoder control variables
volatile int encoderCount = 0;
  // Encoder pins
  pinMode(ENCODER_PIN_A, INPUT_PULLUP);
  pinMode(ENCODER_PIN_B, INPUT_PULLUP);
  // Si5351 contrtolers pins
  pinMode(SWITCH_CMD, INPUT_PULLUP);
  pinMode(BUTTON_UP,  INPUT_PULLUP);
  pinMode(BUTTON_DOWN, INPUT_PULLUP);
  // Initiating the OLED Display
  display.begin(&Adafruit128x64, I2C_ADDRESS);
  display.setFont(Adafruit5x7);
  display.set1X();
  display.clear();
  display.setCursor(17, 0);
  display.print("Multipurpose");
  display.setCursor(33, 1);
  display.print("Signal");
  display.setCursor(23, 2);
  display.print("Generator");
  display.setCursor(22, 5);
  display.print("BY ");
  delay(4000);
  display.clear();
  vfoFreq = favorite[currentFavorite];
  currentOutputClock[currentClock] = vfoFreq;
  showStatus();
  // Initiating the Signal Generator (si5351)
  si5351.init(SI5351_CRYSTAL_LOAD_8PF, 0, 0);
  // Adjusting the frequency (see how to calibrate the Si5351 - example si5351_calibration.ino)
  si5351.set_correction(CORRECTION_FACTOR, SI5351_PLL_INPUT_XO);
  si5351.set_pll(SI5351_PLL_FIXED, SI5351_PLLA);
  si5351.set_freq(vfoFreq, (si5351_clock) currentClock); // Start CLK0 (VFO)
  si5351.drive_strength(SI5351_CLK0, SI5351_DRIVE_8MA);
  // Disable CLK 1 and 2 outputs
  si5351.output_enable(SI5351_CLK1, 0);
  si5351.output_enable(SI5351_CLK2, 0);
  si5351.update_status();
  // Encoder interrupt
  attachInterrupt(digitalPinToInterrupt(ENCODER_PIN_A), rotaryEncoder, CHANGE);
  attachInterrupt(digitalPinToInterrupt(ENCODER_PIN_B), rotaryEncoder, CHANGE);
// Use Rotary.h and  Rotary.cpp implementation to process encoder via interrupt
void rotaryEncoder()
{ // rotary encoder events
  uint8_t encoderStatus = encoder.process();
  if (encoderStatus)
    if (encoderStatus == DIR_CW)
      encoderCount = 1;
      encoderCount = -1;
// Show Signal Generator Information
// Verificar setCursor() em https://github.com/greiman/SSD1306Ascii/issues/53
void showStatus()
  char aux[15];
  double vfo = vfoFreq / 100000.0;
  dtostrf(vfo,5,3,aux);
  display.setCursor(0, 0);
  display.set2X();
  display.print("          ");
  display.print(aux);
  display.setCursor(95,2);
  display.set1X();
  display.print("KHz");
  display.setCursor(0, 4);
  display.print("Step: ");
  display.print(step[currentStep].name);
  display.print(" - ");
  display.print(clk[currentClock]);
  display.setCursor(0, 6);
  display.print("Command: ");
  display.print(cmd[currentCommand]);
// Change the frequency (increment or decrement)
// direction parameter is 1 (clockwise) or -1 (counter-clockwise)
void changeFreq(int direction)
  vfoFreq += step[currentStep].value * direction; // currentStep * direction;
  // Check the VFO limits
  if (vfoFreq > MAX_VFO )
    vfoFreq = MIN_VFO;
  else if (vfoFreq < MIN_VFO)
    vfoFreq = MAX_VFO;
void doCommandUp() {
  display.clear();
  if ( currentCommand == CMD_STEP )
    currentStep = (currentStep < lastStepVFO) ? (currentStep + 1) : 0;
  else if (currentCommand == CMD_FAVORITE )
    currentFavorite = (currentFavorite < lastFavorite) ? (currentFavorite + 1) : 0;
    currentClock = (currentClock < lastCurrentOutputClock) ? (currentClock + 1) : 0;
    vfoFreq = currentOutputClock[currentClock];
  delay(200);
void doCommandDown() {
  display.clear();
    currentStep = (currentStep > 0) ? (currentStep - 1) : lastStepVFO;
  else if (currentCommand == CMD_FAVORITE)
    currentFavorite = (currentFavorite > 0) ? (currentFavorite - 1) : lastFavorite;
    currentClock = (currentClock > 0) ? (currentClock - 1) : lastCurrentOutputClock;
  delay(200);
  // Check if the encoder has moved.
  if (encoderCount != 0)
    if (encoderCount == 1)
      changeFreq(1);
      changeFreq(-1);
    encoderCount = 0;
  // Switch the current command control (step or favorite frequencies)
  if (digitalRead(SWITCH_CMD) == LOW) {
    display.clear();
    currentCommand = (currentCommand >= 2)? 0: (currentCommand + 1);;
    showStatus();
    delay(200);
  } else if (digitalRead(BUTTON_UP) == LOW) {
    doCommandUp();
    showStatus();
  } else if (digitalRead(BUTTON_DOWN) == LOW) {
    doCommandDown();
    showStatus();
  if (isFreqChanged)
    showStatus();
    isFreqChanged = false;
  delay(50);
I must be misunderstanding, you want to display 455.400 instead of 12.65? Then just change the code to (x * 36.0) where x is the name of the variable containing 12.65
