I am needing help with this sketch.
It’s with an Arduino nano and a SI5351 clock generator. The generator has 3 outputs that output a square wave all the way up to 200mhz or so. Clk 0, clk 1, clk 2…. I am only using clk 0 and 1…. What I’m needing it to do is use a pin on the arduino, lets say pin 7. To decide which output turns on or off. What I want is if pin 7 is high clk 0 is off and clk 1 is on… if pin 7 is low clk 0 is on and clk 1 is off… I’ve been scratching my head for a while here without any luck. Any help would be appreciated. I will post the sketch right underneath this.
There must also be something different in this code because the way it currently sits even if I enable clk 1 it does not start outputting a frequency till I go to clock one on the display and turn the encoder left or right then it starts outputting. Not sure why that is either.
#include <si5351.h>
#include <Wire.h>
#include "Rotary.h"
#include "SSD1306Ascii.h"
#include "SSD1306AsciiAvrI2c.h"
// Enconder PINs
#define ENCODER_PIN_A 3 // Encoder pin A
#define ENCODER_PIN_B 2 // Encoder pin B
#define SWITCH_CMD 4 // ENCODER button or regular push button
#define BUTTON_UP 6 // Button up command
#define BUTTON_DOWN 5 // Button down command
#define CMD_STEP 0
#define CMD_FAVORITE 1
#define CMD_CLK 2
// OLED Diaplay constants
#define I2C_ADDRESS 0x3C
#define RST_PIN -1 // Define proper RST_PIN if required.
// Change this value bellow (CORRECTION_FACTOR) to 0 if you do not know the correction factor of your Si5351A.
//#define CORRECTION_FACTOR -13500 // See how to calibrate your Si5351A (0 if you do not want).
#define CORRECTION_FACTOR 160300
#define MIN_VFO 3276800LLU
#define MAX_VFO 16000000000LLU // VFO max. frequency 30MHz
// Struct for step
typedef struct
char *name; // step label: 50Hz, 10Hz, 500Hz and 100KHz
long value; // Frequency value (unit 0.01Hz See documentation) to increment or decrement
} Step;
// Steps database. You can change the Steps and numbers of steps here if you need.
Step step[] = {
{(char *)"1Hz", 100}, // Minimum Frequency step (incremente or decrement) 1Hz
{(char *)"100Hz", 10000},
{(char *)"1KHz", 100000},
{(char *)"10KHz", 1000000},
{(char *)"500KHz", 50000000},
{(char *)"1MHz", 100000000}}; // Maximum frequency step 500KHz
// Calculate the index of last position of step[] array
const int lastStepVFO = (sizeof step / sizeof(Step)) - 1;
int currentStep = 4;
// Your favotite frequencies
uint64_t favorite[] = {3276800LLU, 350000000LLU, 710000000LLU, 1598800000LLU, 1070000000LLU, 1200000000LLU,
1350000000LLU, 1600000000LLU, 2000000000LLU, 2400000000LLU, 2700000000LLU, 2800000000LLU,
3200000000LLU,4600000000LLU, 5000000000LLU, 10000000000LLU, 13300000000LLU, 14400000000LLU};
const int lastFavorite = (sizeof favorite / sizeof(uint64_t) ) - 1;
int currentFavorite = 3;
uint64_t currentOutputClock[]{1070000000LLU, 1350000000LLU, 3276800LLU}; // Stores the current clock on CLK0, CLK1 and CLK2
const int lastCurrentOutputClock = (sizeof currentOutputClock / sizeof(uint64_t)) - 1;
int currentClock = 0; // current clock output 0
int currentCommand = CMD_STEP;
char *cmd[] = {(char *) "Step", (char *) "Favorite", (char *) "Out. Clk" };
char *clk[] = {(char *) "CLK0", (char *) "CLK1", (char *) "CLK2" };
// Encoder controller
Rotary encoder = Rotary(ENCODER_PIN_A, ENCODER_PIN_B);
// OLED - Declaration for a SSD1306 display connected to I2C (SDA, SCL pins)
SSD1306AsciiAvrI2c display;
// The Si5351 instance.
Si5351 si5351;
bool isFreqChanged = true;
bool clearDisplay = false;
uint64_t vfoFreq;
uint64_t vfoLastValue;
// Encoder control variables
volatile int encoderCount = 0;
// Encoder pins
pinMode(ENCODER_PIN_A, INPUT_PULLUP);
pinMode(ENCODER_PIN_B, INPUT_PULLUP);
// Si5351 contrtolers pins
pinMode(SWITCH_CMD, INPUT_PULLUP);
pinMode(BUTTON_UP, INPUT_PULLUP);
pinMode(BUTTON_DOWN, INPUT_PULLUP);
// Initiating the OLED Display
display.begin(&Adafruit128x64, I2C_ADDRESS);
display.setFont(Adafruit5x7);
display.set1X();
display.clear();
display.setCursor(17, 0);
display.print("Multipurpose");
display.setCursor(33, 1);
display.print("Signal");
display.setCursor(23, 2);
display.print("Generator");
display.setCursor(22, 5);
display.print("BY WZ5TX");
delay(4000);
display.clear();
vfoFreq = favorite[currentFavorite];
currentOutputClock[currentClock] = vfoFreq;
showStatus();
// Initiating the Signal Generator (si5351)
si5351.init(SI5351_CRYSTAL_LOAD_8PF, 0, 0);
// Adjusting the frequency (see how to calibrate the Si5351 - example si5351_calibration.ino)
si5351.set_correction(CORRECTION_FACTOR, SI5351_PLL_INPUT_XO);
si5351.set_pll(SI5351_PLL_FIXED, SI5351_PLLA);
si5351.set_freq(vfoFreq, (si5351_clock) currentClock); // Start CLK0 (VFO)
// Disable CLK 1 and 2 outputs
si5351.output_enable(SI5351_CLK1, 0);
si5351.output_enable(SI5351_CLK2, 0);
si5351.update_status();
// Encoder interrupt
attachInterrupt(digitalPinToInterrupt(ENCODER_PIN_A), rotaryEncoder, CHANGE);
attachInterrupt(digitalPinToInterrupt(ENCODER_PIN_B), rotaryEncoder, CHANGE);
// Use Rotary.h and Rotary.cpp implementation to process encoder via interrupt
void rotaryEncoder()
{ // rotary encoder events
uint8_t encoderStatus = encoder.process();
if (encoderStatus)
if (encoderStatus == DIR_CW)
encoderCount = 1;
encoderCount = -1;
// Show Signal Generator Information
// Verificar setCur
void showStatus()
char aux[15];
double vfo = vfoFreq / 100000.0;
dtostrf(vfo,5,3,aux);
display.setCursor(0, 0);
display.set2X();
display.print(" ");
display.print(aux);
display.setCursor(95,2);
display.set1X();
display.print("KHz");
display.setCursor(0, 4);
display.print("Step: ");
display.print(step[currentStep].name);
display.print(" - ");
display.print(clk[currentClock]);
display.setCursor(0, 6);
display.print("Command: ");
display.print(cmd[currentCommand]);
// Change the frequency (increment or decrement)
// direction parameter is 1 (clockwise) or -1 (counter-clockwise)
void changeFreq(int direction)
vfoFreq += step[currentStep].value * direction; // currentStep * direction;
// Check the VFO limits
if (vfoFreq > MAX_VFO )
vfoFreq = MIN_VFO;
else if (vfoFreq < MIN_VFO)
vfoFreq = MAX_VFO;
void doCommandUp() {
display.clear();
if ( currentCommand == CMD_STEP )
currentStep = (currentStep < lastStepVFO) ? (currentStep + 1) : 0;
else if (currentCommand == CMD_FAVORITE )
currentFavorite = (currentFavorite < lastFavorite) ? (currentFavorite + 1) : 0;
currentClock = (currentClock < lastCurrentOutputClock) ? (currentClock + 1) : 0;
vfoFreq = currentOutputClock[currentClock];
delay(200);
void doCommandDown() {
display.clear();
currentStep = (currentStep > 0) ? (currentStep - 1) : lastStepVFO;
else if (currentCommand == CMD_FAVORITE)
currentFavorite = (currentFavorite > 0) ? (currentFavorite - 1) : lastFavorite;
currentClock = (currentClock > 0) ? (currentClock - 1) : lastCurrentOutputClock;
delay(200);
// Check if the encoder has moved.
if (encoderCount != 0)
if (encoderCount == 1)
changeFreq(1);
changeFreq(-1);
encoderCount = 0;
// Switch the current command control (step or favorite frequencies)
if (digitalRead(SWITCH_CMD) == LOW) {
display.clear();
currentCommand = (currentCommand >= 2)? 0: (currentCommand + 1);;
showStatus();
delay(200);
} else if (digitalRead(BUTTON_UP) == LOW) {
doCommandUp();
showStatus();
} else if (digitalRead(BUTTON_DOWN) == LOW) {
doCommandDown();
showStatus();
if (isFreqChanged)
showStatus();
isFreqChanged = false;
delay(50);
