Si5351A two transmissions at same time (?)
Hello guys.
I'm using Si5351A for transmitting on 14 MHz frequency. This chip has 3 clocks (CLK0, CLK1 and CLK2).
I would kindly ask you if it is possible to transmit (generate clock signal) at same time on two different frequency, e.g. 14097100 and 14097200 Hz.
In particular, if that is possible using same antenna (same wire connected to CLK0 and CLK1 pins for example).
Thank you so much for your appreciated help.
Roberto.
