Hello good weekends, I am not getting data from the esp8266-01 and si7021 module I am working on, I would be glad if you help?
The purpose of this project is to send temperature and humidity information from esp8266 to the web. Si7021 is a temperature and humidity sensor. Si7021 datasheet * "https://cdn.sparkfun.com/datasheets/Sensors/Weather/Si7021.pdf"
#include <ESP8266WiFi.h>
#include <ESP8266HTTPClient.h>
#include <WiFiClient.h>
//Sensor
#include "SparkFun_Si7021_Breakout_Library.h"
#include <Wire.h>
float humidity = 0;
float tempf = 0;
Weather sensor;
const char* ssid = "EA Research Center";
const char* password = "******";
const char* serverName = "example.php*********";
String apiKeyValue = "**********";
String sensorName = "si7021";
String sensorLocation = "Berlin";
String deviceID = "1";
sensor.begin();
WiFi.begin(ssid, password);
Serial.println("Connecting");
Serial.print(".");
Serial.println("");
Serial.print("Connected to WiFi network with IP Address: ");
//humidity = sensor.getRH();
//temp = sensor.getTemp();
if (WiFi.status() == WL_CONNECTED) {
//getWeather();
tempf = sensor.getTemp();
HTTPClient http;
http.begin(serverName);
http.addHeader("Content-Type", "application/x-www-form-urlencoded");
String httpRequestData = "api_key=" + apiKeyValue + "&sensor=" + sensorName
+ "&location=" + sensorLocation + "&value1=" + String(tempf)
+ "&value2=" + String(humidity) + "&value3=" + deviceID + "";
Serial.print("httpRequestData: ");
Serial.println(httpRequestData);
int httpResponseCode = http.POST(httpRequestData);
if (httpResponseCode > 0) {
Serial.print("HTTP Response code: ");
Serial.println(httpResponseCode);
else {
Serial.print("Error code: ");
http.end();
else {
Serial.println("WiFi Disconnected");
delay(30000);
void getWeather()
