I am using Si7021 silicon lab's temperature and humidity sensor and APD300 light sensor together in my PCB board, I am also using STM32F103 Arduino compatible microcontroller which communicates the sensors through the I2C protocol, I have tested it before and the sensors were reading the correct sensor data in the Arduino Serial monitor, but now my humidity and temperature sensor is reading way too much values like "219982828282 C" even though I am using the correct pull-up resistors, I was wondering if there is something wrong with the code I am using (Found it from the internet). I have attached the source code I used and the serial monitor output of my sensors.
#include <Wire.h>
// SI7021 I2C address is 0x40(64)
#define Addr 0x40
// Initialise I2C communication as MASTER
Wire.begin();
// Initialise serial communication, set baud rate = 9600
// Start I2C transmission
Wire.beginTransmission(Addr);
// Stop I2C transmission
Wire.endTransmission();
delay(300);
unsigned int data[2];
// Send humidity measurement command, NO HOLD MASTER
Wire.write(0xF5);
// Request 2 bytes of data
Wire.requestFrom(Addr, 2);
// Read 2 bytes of data
// humidity msb, humidity lsb
if(Wire.available() == 2)
data[0] = Wire.read();
data[1] = Wire.read();
// Convert the data
float humidity = ((data[0] * 256.0) + data[1]);
humidity = ((125 * humidity) / 65536.0) - 6;
// Send temperature measurement command, NO HOLD MASTER
Wire.write(0xF3);
// temp msb, temp lsb
// Convert the data
float temp = ((data[0] * 256.0) + data[1]);
float cTemp = ((175.72 * temp) / 65536.0) - 46.85;
float fTemp = cTemp * 1.8 + 32;
// Output data to serial monitor
Serial.print("Relative humidity : ");
Serial.print(humidity);
Serial.println(" % RH");
Serial.print("Temperature in Celsius : ");
Serial.print(cTemp);
Serial.println(" C");
Serial.print("Temperature in Fahrenheit : ");
Serial.print(fTemp);
Serial.println(" F");
Arduino Serial Monitor Output
Illumination: 101
Relative humidity : 65802760.00 % RH
Temperature in Celsius : 92502848.00 C
Temperature in Fahrenheit : 166505152.00 F
