Hello,
Please refer to the code below where digout is initialized as output and set high. When the code is loaded to the Uno, the pin does go hi but and i press M, the pin is pulsed low! before going high again. This would applies to whatever Uno's pins. The net effect is that launching the monitor my destroy a board's power on state set by the "Setup()" procedure!
Is this unavoidable?
Does launching the serial monitor forces a full reset an re-executes Setup()?
What is the suggested workaround?
Thanks in advance for your time
Guy
#define digout 4
pinMode(digout, OUTPUT);
digitalWrite(digout, HIGH);
Serial.println("press kb");
while (Serial.available()<=0);
Serial.read();
Serial.println("starting");
