SIGNAL(TIMER0_COMPA_vect) Compiling Error
Hey all, I'm running into an issue when compiling this code and spent about an hour google spelunking trying to figure out what the issue was before turning to the forum and came out confused and empty-handed.
The error I receive is "expected unqualified-id before string constant."
This is a bit of a head-scratcher for me, any help/troubleshooting assistance would be greatly appreciated =). Thank you in advance =)
If it matters I'm using a Mega 2560 for this project.
//                           BrewShark v1                                 //
// Change value of hltSIZE to match the max volume in your HLT            //
#include <LiquidCrystal.h>
//#include <DueTimer.h>
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
int lcd_key     = 0;
int adc_key_in  = 0;
float current_volume = 0;                //Current total volume passed though flow meter
float target_volume = 23;                //Total desired volume
float adjustment_volume = 0;             //Adjustment volume to take into account delays in solenoid closing. Subtracted from the current volume.
#define btnRIGHT  0
#define btnUP     1
#define btnDOWN   2
#define btnLEFT   3
#define btnSELECT 4
#define btnNONE   5
/*==========BUTTON DEFINITION==========*/
  int read_LCD_buttons(){ // read the buttons
  adc_key_in = analogRead(0); // read the value from the sensor
 if (adc_key_in > 1000) return btnNONE;
 if (adc_key_in < 0) return btnRIGHT;
 if (adc_key_in < 210) return btnUP;
 if (adc_key_in < 410) return btnDOWN;
 if (adc_key_in < 628) return btnLEFT;
 if (adc_key_in < 828) return btnSELECT;
#define hltSIZE   50                       //Size of the Hot Liquor Tun in litres
#define SOLENOIDPIN 13                      //Solenoid relay on Pin 13
#define FLOWSENSORPIN 2                    //Flow sensore on Pin 2
// count how many pulses
volatile uint16_t pulses = 0;
// track the state of the pulse pin
volatile uint8_t lastflowpinstate;
// you can try to keep time of how long it is between pulses
volatile uint32_t lastflowratetimer = 0;
// and use that to calculate a flow rate
volatile float flowrate;
// Interrupt is called once a millisecond, looks for any pulses from the sensor
SIGNAL(TIMER0_COMPA_vect) {
    uint8_t x = digitalRead(FLOWSENSORPIN);
      if (x == lastflowpinstate) {
      lastflowratetimer++;
      return; // nothing changed!
  if (x == HIGH) {
    //low to high transition!
    pulses++;
  lastflowpinstate = x;
  flowrate = 1000.0;
  flowrate /= lastflowratetimer; // in hertz
void useInterrupt(boolean v) {
  if (v) {
    // Timer0 is already used for millis() - we'll just interrupt somewhere
    // in the middle and call the "Compare A" function above
    OCR0A = 0xAF;
    TIMSK0 |= _BV(OCIE0A);
    // do not call the interrupt function COMPA anymore
    TIMSK0 &= ~_BV(OCIE0A);
  Serial.print("Flow sensor test!");
  digitalWrite(SOLENOIDPIN,LOW);           //ACTIVE HIGH RELAY PUT THIS FIRST TO ENSURE PIN IS IN CORRECT STATE BEFORE WE INIT IT
  digitalWrite(FLOWSENSORPIN, HIGH);
  pinMode(SOLENOIDPIN, OUTPUT);
  pinMode(FLOWSENSORPIN, INPUT);
  lcd.begin(16, 2);                        // start the library
  printBanner(2000);                       // show banner for 2 seconds
  lcd.clear();
  printLabels();
  lastflowpinstate = digitalRead(FLOWSENSORPIN);
  useInterrupt(true);
  while(current_volume < (target_volume - adjustment_volume))
    dowork();
  digitalWrite(SOLENOIDPIN,LOW);          //Close solenoid
  lcd.setCursor(0,0);
  lcd.print("  VALVE CLOSED  ");
  lcd.setCursor(0,1);
  lcd.print("   TARGET HIT   ");
  //Debug Messaging
  Serial.println("  VALVE CLOSED  ");
  Serial.println("   TARGET HIT   ");
void printBanner(int bannerdelay)
  lcd.setCursor(0,0);
  lcd.print("        ^       ");
  lcd.setCursor(0,1);
  lcd.print("  >=BrewShark>  ");
  delay(bannerdelay);
void printLabels()
  lcd.setCursor(0,0);
  lcd.print("Set Vol: ");
  lcd.setCursor(0,1);
  lcd.print("Cur Vol: ");
// read the buttons
  /*  OLD BUTTONS at 3.3V
  if (adc_key_in < 50)   return btnRIGHT;
  if (adc_key_in < 195)  return btnSELECT;
  if (adc_key_in < 380)  return btnUP;
  if (adc_key_in < 555)  return btnDOWN;
  if (adc_key_in < 790)  return btnLEFT;
  if (adc_key_in > 1000 && adc_key_in < 1050) return btnNONE;
  if (adc_key_in > 130 && adc_key_in < 160)  return btnUP;
  if (adc_key_in > 300 && adc_key_in < 350)  return btnDOWN;
  if (adc_key_in > 480 && adc_key_in < 520)  return btnLEFT;
  if (adc_key_in > 700 && adc_key_in < 800)  return btnSELECT;
  return btnNONE;
void dowork()
  //Serial.print("Freq: "); Serial.println(flowrate);        //Uncomment these two lines to monitor the freq/pulses
  //Serial.print("Pulses: "); Serial.println(pulses, DEC);
  float liters = pulses;
  liters /= 7.5;
  liters /= 60.0;
  current_volume = liters;
  //Debug Messaging
  Serial.print("Cur: "); Serial.println(current_volume);
  Serial.print("Tar: "); Serial.println(target_volume);
  //Print the target volume value in litres
  lcd.setCursor(11,0);
  lcd.print(target_volume,2);
  lcd.setCursor(15,0);
  lcd.print("L");
  //Print the current volume value in litres
  lcd.setCursor(11,1);
  lcd.print(current_volume,2);
  lcd.setCursor(15,1);
  lcd.print("L");
  lcd_key = read_LCD_buttons();    // read the buttons
  switch (lcd_key)               // depending on which button was pushed, we perform an action
  case btnRIGHT:
     if (digitalRead(SOLENOIDPIN == HIGH))
             digitalWrite(SOLENOIDPIN,LOW);       //STOP FLOW
      Serial.println("Solenoid Closed");
  case btnLEFT:
     if (digitalRead(SOLENOIDPIN == LOW))
             digitalWrite(SOLENOIDPIN,HIGH);       //START FLOW
      Serial.println("Solenoid Open");
  case btnUP:
      if (target_volume >= hltSIZE)  //don't go larger than the size of the vessel
        target_volume = hltSIZE;
        target_volume += 0.1;
  case btnDOWN:
      if (target_volume <= 0)      //don't go below zero
        target_volume = 0;
        target_volume -= 0.1;
  case btnNONE:
There are many problems with that code, beginning with this incomplete function code:
Where did you find it? I'm guessing that it is pretty old, since no one uses SIGNAL for an ISR any more.
Found on an older homebrew forum where most posts are from around 2010 or so. I think I'll look around a bit for an updated version. Thanks for taking a look. I'll go ahead and close this out.
That function is defined again, later in the code, and if you remove the first, incomplete definition, the code compiles without error.
//                           BrewShark v1                                 //
int lcd_key     = 0;
int adc_key_in  = 0;
#define btnRIGHT  0
#define btnUP     1
#define btnDOWN   2
#define btnLEFT   3
#define btnSELECT 4
#define btnNONE   5
ISR (TIMER0_COMPA_vect) {
  if (x == HIGH) {
    pulses++;
  flowrate = 1000.0;
  if (v) {
    OCR0A = 0xAF;
  lcd.clear();
  printLabels();
  useInterrupt(true);
    dowork();
  lcd.setCursor(0,0);
  lcd.setCursor(0,1);
  //Debug Messaging
  lcd.setCursor(0,0);
  lcd.print("        ^       ");
  lcd.setCursor(0,1);
  delay(bannerdelay);
void printLabels()
  lcd.setCursor(0,0);
  lcd.setCursor(0,1);
// read the buttons
  return btnNONE;
void dowork()
  liters /= 7.5;
  liters /= 60.0;
  //Debug Messaging
  lcd.print("L");
  lcd.print("L");
  case btnRIGHT:
  case btnLEFT:
  case btnUP:
  case btnDOWN:
        target_volume = 0;
  case btnNONE:
