Signal timing
I'm working on a project with stepper motors. I have them turn every 20 seconds. It takes 1 second for them to complete that. I'm wondering if the one second will accumulate over time, or if it starts counting again as soon as the signal to turn is sent. I will post the code below but I'm not sure if it will help.
Thanks- Matt
#include <Wire.h>
#include <Adafruit_MotorShield.h>
#include "utility/Adafruit_PWMServoDriver.h"
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
Adafruit_StepperMotor *myMotor = AFMS.getStepper(100, 2);
AFMS.begin();
myMotor->setSpeed(1);
myMotor->step(1, FORWARD, MICROSTEP);
delay(20000);
I know nothing about the motor shields. Here's what I would do. Get a stopwatch and start it when the motors stop moving. Stop the watch when the motors stop moving the second time. You don't need to be perfect on your timing, just well enough to know if there's an extra second in the execution.
As for if that extra second will accumulate over time depends on the application. If you need the motors to turn in sync with something else, one second is more than enough to notice. After one minute, the motors will be 3 seconds late to update. If that's the case, just change "delay(20000)" to "delay(19000)". But this is just if the controller has to take the extra second delay. You could try this (which should work either way):
#include <Wire.h>
unsigned long Now;
  AFMS.begin();
Now=millis();
  while(millis()-Now <= 20000){
  //do nothing
  myMotor->step(1, FORWARD, MICROSTEP); //is this supposed to be here?
