Signal()
Hey Guys
i'm currently working on a project where i have modeltrain signals. I sumbled upon the function signal()
  1. what does it do
  2. how can i define it in an enum without me getting the error of primary expression
if it's a bit xy sry
Thanks
You have the code. We don't
Please post a full sketch and/or details of where you found the function
Sorry, ive got the problem solved with the error an declaration
EDIT: just the normal function signal() i think its native since i dont have any libarys installed
signal()
That cannot be the solution as that line of code will not compile
Please post the sketch where the function is used as it is not a "native" function
Btw it is native function of cpp
https://en.cppreference.com/w/cpp/utility/program/signal
Regards
To quote from C++ Signal Handling
Signals are the interrupts delivered to a process by the operating system which can terminate a program prematurely. You can generate interrupts by pressing Ctrl+C on a UNIX, LINUX, Mac OS X or Windows system.
The Arduino does not have an Operating System. Can you see a problem ?
were you hoping that the signal() function would provide functionality to your program ?
I note that you have still not posted a sketch that uses the function, but I am not surprised bearing in mind what the function does
From the AVRGCC library manual:
#define SIGNAL ( vector )
Introduces an interrupt handler function that runs with global interrupts initially disabled.
This is the same as the ISR macro without optional attributes.
Deprecated:
Do not use SIGNAL() in new code. Use ISR() instead.
Sorry if it was unclear it was a general question this was not associated no my code that im currently on
