Signalanalyzer with avr
I've been writing a code to analyze the signal of a sensor. To test the code I wrote a signalgenerator which outputs a pwm Signal with variable duty cycle and frequency.
The analyzer has to print the recieved frequency and duty, but the serial monitor isn't displaying anything or just question marks.
#define CPUclk 16000000UL
volatile  uint16_t captureValue1;
volatile  uint16_t captureValue2;
volatile unsigned long ovf_counter;
volatile int duty;
volatile int frequenz;
volatile uint8_t printFlag;
volatile int i = 1;
int main() { //Normal Mode Timer 1 16Bit
  init();
  DDRB &= ~ (1 << DDB0); //PIN8
  TCCR1A = 0;
  TCCR1B = 0;
  TCCR1B |= (1 << CS10); //Prescaler 1
  TCCR1B |= (1 << ICNC1);
  TCCR1B &= ~ (1 << ICES1); //NC & Input Capture steigende Flanke
  TIMSK1 |= (1 << TOIE1) | (1 << ICIE1); // Ovf Interrupt & Input Capture ein
  sei();
  while (1) {
    if (printFlag) {
      printFlag = 0;
      Serial.print(frequenz);
      Serial.print("Hz");
      Serial.print("---");
      Serial.print(duty);
      Serial.println("%");
ISR(TIMER1_OVF_vect) {
  ovf_counter = 0; // Neue Periode Flankencounter reseten
ISR(TIMER_CAPT_vect) {
  printFlag = 1;
  if (i) {
    TCCR1B |= (1 << ICES1); //steigende Flanke
    uint16_t captureValue1 = ICR1;  //Wert bei fallender Flanke speichern
    i = 0;
    ovf_counter++;  //Flanken in einer Periode zählen
  else {
    TCCR1B &= ~ (1 << ICES1); // fallende Flanke
    uint16_t captureValue2 = ICR1; //Wert bei steigender Flanke speichern
    i = 1;
  //duty in % duty = HIGH/LOW
  duty = 100 * ((unsigned long)(captureValue2 - captureValue1) / (unsigned long)(65535 - (captureValue2 - captureValue1)));
  frequenz = CPUclk * 2 / ovf_counter;
  // f = Frequenz von Arduino / ( Anzahl der auftretenden Flanken * 0.5 )
Are you programming that through the IDE? and using the Serial Monitor? That is not a normal sketch.
