Signature Error - Burning Bootloader AtTiny85 with Arduino Atmega2560 Clone - Expected 1E 93 0B for AtTiny got 0xff0000
My error code:
"C:\Users\DripTooHard\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\DripTooHard\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -v -v -v -pattiny85 -cstk500v1 -PCOM9 -b19200 -e -Uefuse:w:0xff:m -Uhfuse:w:0xdf:m -Ulfuse:w:0xfe:m
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\DripTooHard\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM9
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
avrdude: Send: 0 [30]   [20]
avrdude: ser_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x03
avrdude: Recv: . [14]
avrdude: Recv: . [10]
         AVR Part                      : ATtiny85
         Chip Erase delay              : 400000 us
         PAGEL                         : P00
         BS2                           : P00
         RESET disposition             : possible i/o
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    12     4    0 no        512    4      0  4000  4500 0xff 0xff
           flash         65     6    32    0 yes      8192   64    128 30000 30000 0xff 0xff
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
avrdude: Send: A [41] . [80]   [20]
avrdude: Recv: . [02]
avrdude: Send: A [41] . [81]   [20]
avrdude: Recv: . [01]
avrdude: Send: A [41] . [82]   [20]
avrdude: Recv: . [12]
avrdude: Send: A [41] . [98]   [20]
avrdude: Recv: . [00]
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
avrdude: Send: A [41] . [84]   [20]
avrdude: Send: A [41] . [85]   [20]
avrdude: Send: A [41] . [86]   [20]
avrdude: Send: A [41] . [87]   [20]
avrdude: Send: A [41] . [89]   [20]
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: Send: B [42] . [14] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [ff] . [ff] . [ff] . [ff] . [00] @ [40] . [02] . [00] . [00] . [00]   [20] . [00]   [20]
avrdude: PAGEL and BS2 signals not defined in the configuration file for part ATtiny85, using dummy values
avrdude: Send: E [45] . [05] . [04] . [d7] . [a0] . [01]   [20]
avrdude: Send: P [50]   [20]
avrdude: AVR device initialized and ready to accept instructions
Reading | avrdude: Send: V [56] 0 [30] . [00] . [00] . [00]   [20]
avrdude: Recv: . [ff]
avrdude: Send: V [56] 0 [30] . [00] . [01] . [00]   [20]
################avrdude: Send: V [56] 0 [30] . [00] . [02] . [00]   [20]
################################## | 100% 0.02s
avrdude: Device signature = 0xff0000
avrdude: Expected signature for ATtiny85 is 1E 93 0B
         Double check chip, or use -F to override this check.
avrdude: Send: Q [51]   [20]
avrdude done.  Thank you.
Failed chip erase: uploading error: exit status 1
I have the following connections between the ICSP pins on the Atmega to the AtTiny85:
1 -> Pin 1
2 -> VCC
3 -> Pin 2
4 -> Pin 0
5 -> Reset
GND -> GND
Furthermore I have added a 10 nano-F capacitor between GND and RESET on the Atmega.
I used the standard ArduinoISP to flash the Atmega2560 with the following settings:
After succesfully flashing the ArduinoISP script to the Atemga2560 I tried to burn bootloader with the following settings:
Processor: AtTiny 85
Board: AtTiny 25/45/85
Programmer: Arduino as ISP
Clock: External or Internal 8 MhZ (Tried both got the same error).
Which tiny85 core are you using?
My receipt says AVR 8 Pin 20MHz 8K 4AD
This thread will answer the question, "what is a core" >> Explain what is meant by "Arduino core" - Arduino Stack Exchange
You must choose the right board in the IDE Tools, Boards menu to load the right bootloader to the right chip.
I have found the best (in my opinion) core for the tiny85 class parts to be the ATTinyCore by Spence Konde. The core is available via the IDE boards manager and installation instructions are available in the GitHub page that I linked.
The ATTinyCore makes it easy to choose the bootload options like processor type, clock speed, clock source, etc.
If you still have trouble, please post a wiring diagram showing how the tiny85 is connected to the Mega and all other wiring.
Alright,
I tried using that core with the Optibooter and no booter options.
I got the same result with the optibooter and I got "Requires programmer" for the "no booter" option.
As for my diagram here is a "modular" version of it:
I have described the pins verbally in my original post.
Looks OK.
Why didn't you label the wiring? I had to look up the pinouts to trace the wiring. I should not have to do that.
ATtiny85's anticipated signature is 1E 93 0B. If you want to override this check, use -F or double-check chip. Bootloader burning error.
