Sim 800l adafruit fona library
Hello.
I’m used sim800l, dht22, ds3231,…
For sim800l adafruit fona library
I tried the “receive call” sample code of this library. “interrupt pin d2 connected”.
Incoming calls “interrupt” is working.
but the code stops when I send an SMS to the module.
(incoming sms —> code stop)
Serial monitor
looked at serial monitor. during incoming sms;
serial monitor> incoming cal …
writing and not runing code
Code:
#include “Adafruit_FONA.h”
// Pins which are connected to the FONA.
// Note that this is different from FONAtest!
#define FONA_RX 3
#define FONA_TX 4
#define FONA_RST 5
// Note you need to map interrupt number to pin number
// for your board. On an Uno & Mega interrupt 0 is
// digital pin 2, and on a Leonardo interrupt 0 is
// digital pin 3. See this page for a complete table:
// http://arduino.cc/en/Reference/attachInterrupt
// Make sure this interrupt pin is connected to FONA RI!
#define FONA_RI_INTERRUPT 0
// We default to using software serial. If you want to use hardware serial
// (because softserial isnt supported) comment out the following three lines
// and uncomment the HardwareSerial line
#include <SoftwareSerial.h>
SoftwareSerial fonaSS = SoftwareSerial(FONA_TX, FONA_RX);
SoftwareSerial *fonaSerial = &fonaSS;
// Hardware serial is also possible!
// HardwareSerial *fonaSerial = &Serial1;
Adafruit_FONA fona = Adafruit_FONA(FONA_RST);
Serial.println(F(“FONA incoming call example”));
Serial.println(F(“Initializing…(May take 3 seconds)”));
fonaSerial->begin(4800);
if (! fona.begin(*fonaSerial)) {
Serial.println(F(“Couldn’t find FONA”));
while(1);
Serial.println(F(“FONA is OK”));
// Enable incoming call notification.
if(fona.callerIdNotification(true, FONA_RI_INTERRUPT)) {
Serial.println(F(“Caller id notification enabled.”));
else {
Serial.println(F(“Caller id notification disabled”));
void loop(){
// Create a small string buffer to hold incoming call number.
char phone[32] = {0};
// Check for an incoming call. Will return true if a call is incoming.
if(fona.incomingCallNumber(phone)){
Serial.println(F(“RING!”));
Serial.print(F("Phone Number: "));
Serial.println(phone);
to the setup part of the code:
fona.setsmsınterrupt (0);
I added again.
The code is breaking when it comes to sms.
Could you help?
how can I do?
IncomingCall.ino (2.01 KB)
Solved
im having the same problem with the incoming calls, how did you solved? please
