SIM 800L, Arduino UNO, MySQL data uploading
'm trying to upload Arduino sensor data results in a table created in a remote MySQL Database with the classical GET method and myfile.php file placed in my website.
Currently I’m able to post data with a following link: http://mywebsite.epizy.com/myfile.php?d1=2.3&d2=3.0
Each time that I try to post this link in my browser a new line is added in my table with correct values.
I have problems when I try to use my Arduino code and SIM800l shield modem (Things Mobile SIM inserted). It seems that something goes wrong.
I’m using following code:
#include <SoftwareSerial.h>
SoftwareSerial gprsSerial(7, 3);
  gprsSerial.begin(19200);
 Serial.println("Config SIM900...");
  delay(2000);
  Serial.println("Done!...");
  gprsSerial.flush();
  Serial.flush();
  // attach or detach from GPRS service
  gprsSerial.println("AT+CGATT?");
  delay(100);
  toSerial();
  // bearer settings
  gprsSerial.println("AT+SAPBR=3,1,\"CONTYPE\",\"GPRS\"");
  delay(2000);
  toSerial();
  // bearer settings
  gprsSerial.println("AT+SAPBR=3,1,\"APN\",\"TM\"");
  delay(2000);
  toSerial();
  // bearer settings
  gprsSerial.println("AT+SAPBR=1,1");
  delay(2000);
  toSerial();
   // initialize http service
   gprsSerial.println("AT+HTTPINIT");
   delay(2000);
   toSerial();
   // set http param value
   gprsSerial.println("AT+HTTPPARA=\"URL\",\"http://mywebsite.epizy.com/myfile.php?d1=2.3&d2=3.0"");
   delay(2000);
   toSerial();
   // set http action type 0 = GET, 1 = POST, 2 = HEAD
   gprsSerial.println("AT+HTTPACTION=0");
   delay(6000);
   toSerial();
   // read server response
   gprsSerial.println("AT+HTTPREAD");
   toSerial();
   gprsSerial.println("");
   gprsSerial.println("AT+HTTPTERM");
   toSerial();
   delay(300);
   delay(10000);
void toSerial()
  while(gprsSerial.available()!=0)
    Serial.write(gprsSerial.read());
So, from serial monitor, I have:
Config SIM900...
Done!...
AT+CGATT?
+CGATT: 1
OK
AT+SAPBR=3,1,"CONTYPE","GPRS"
OK
AT+SAPBR=3,1,"APN","TM"
OK
AT+SAPBR=1,1
OK
AT+HTTPINIT
OK
AT+HTTPPARA="URL","http://sosardgio89.epizy.com/wd3.php?d1=23&dAT+HTTPACTION=0
OK
+HTTPACTION: 0,200,851
AT+HTTPREAD
+HTTPREAD: 851
<html><body><script type="text/ja
AT+HTTPTERM
OK
It seems that the upload is successful but no lines are added in my table!
I post for you the myfile.php file structure uploaded in my web site and in the “htdocs” folder;
<?php
$conex = mysql_connect("sql7.freemysqlhosting.net","sql1234567","1234567");
if(!$conex){
    die("non ok server
".mysql_error());
else{
echo ("DONE");
print ("DONE");}
$db = mysql_select_db("sql1234567", $conex);
if(!$db){
    die("non ok database
".mysql_error());
//$Boton = $_POST["strBoton"];
//$Boton = $_GET["strBoton"];
$sql = "INSERT INTO Save_Data (Date,Time,Value_1,Value_2) VALUES (NOW(),NOW(),'".$_GET["d1"]."','".$_GET["d2"]."') ";
$res = mysql_query($sql,$conex);
Based on my experience I can’t find the problem. Could you help me?
Thanks a lot.
