Hello,Block Diagram.pdf (336.4 KB)
I'm attempting to create a project that requires speed, date & time, longitude & latitude to be sent. My thoughts were to use the GPS on the SIM 808 to retrieve that information and its GSM to send said information.
I've tried connecting according to the datasheet and using a reliable SIM card but the module doesn't connect to the network. Attached is a block diagram of how I've connected the components and pictures of the components themselves.
Kindly assist with suggestions or a solution as to how I could make connections that will result in the module registering network. Thank you in advance.
I haven't worked with them before as such I ain't conversant with them.By proper software do you mean I should code first?If so,are they the AT commands?
