Lately a student group created a mailbox that sent an SMS when mail arrived. I ordered a SIM900 GSM/GPRS ICOMSAT EXPANSION BOARD from Hobbyking for them, but they ran into issues getting Arduino to talk with the board. They tried everything Google had to offer with the latest IDE, but to no avail.
It was finally solved by backtracking the Arduino IDE to 1.6.5 when it started to work.
The question is, do I need to keep an installation of 1.6.5 for SIM projects, or, did we miss something?
Okay, here goes (I was just thinking if anyone had come across the same issue).
The thing is this: Using 1.8.5 with this code doesn't send the message. It does connect to the SIM card shield, and the SIM card finds the network, but this code works only if compiled in an early version of the IDE. Please ignore the comments in Finnish, or, learn Finnish with the code.
The piezo horn is used only to confirm the switch going down. This code does send the message.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(3, 2);
const int mySwitch = 6; // Muuttumaton muuttuja mySwitch on kytkennässä 6
int piezoPin = 7; // Muuttuja pilli on kytkennässä 7
// Määritellään muuttujan mySwitchDown arvoksi false
boolean mySwitchDown = 0;
boolean lastState = 0;
//Sammutetaan ledi
digitalWrite(LED_BUILTIN, LOW);
// Pinni joka määritelty kytkimeksi on input pinni
pinMode(mySwitch, INPUT);
// Sisäinen ledi on yksi output pinni
pinMode(LED_BUILTIN, OUTPUT);
// määritellään mySwitch pinniin HIGH eli 5 volttia
digitalWrite(mySwitch, HIGH);
mySerial.begin(9600); // Setting the baud rate of GSM Module
Serial.begin(9600); // Setting the baud rate of Serial Monitor (Arduino)
delay(100);
mySwitchDown = digitalRead(mySwitch);
if (mySwitchDown != lastState) {
if (mySwitchDown==LOW) {
// Viive seuraavaan loopin alkuun
delay(100);
// Arduinon sisäinen led syttyy
digitalWrite(LED_BUILTIN, HIGH);
// Pilli, hertsit(äänenkorkeus), viive
tone(piezoPin, 1000, 500);
// Viive, johon lisätään pillille annettu viive
delay(1500);
mySerial.println("AT+CMGF=1"); //Sets the GSM Module in Text Mode
delay(1000); // Delay of 1000 milli seconds or 1 second
mySerial.println("AT+CMGS=\"+358505018555\"\r"); // Replace x with mobile number
mySerial.println("I am SMS from GSM Module");// The SMS text you want to send
delay(100);
mySerial.println((char)26);// ASCII code of CTRL+Z
// Jos mySwitchDown ei toteudu
//Arduinon sisäinen ledi sammuu
delay(100);
lastState = mySwitchDown;
void RecieveMessage()
mySerial.println("AT+CNMI=2,2,0,0,0"); // AT Command to receive a live SMS
