Sim Racing 32 Button having Error
HI all ,
I very new on Arduino , recently playing sim racing and saw button make the sim button . so decide to make for my own . get all the part install and setup . sadly I was sticked at Arduino this part
after I Sketch copy from youtube which is
#include <Esplora.h>
//BUTTON BOX
//USE w ProMicro
//Tested in WIN10 + Assetto Corsa
//AMSTUDIO
//20.8.17
#include <Keypad.h>
#include <Joystick.h>
#define ENABLE_PULLUPS
#define NUMROTARIES 4
#define NUMBUTTONS 24
#define NUMROWS 5
#define NUMCOLS 5
byte buttons[NUMROWS][NUMCOLS] = {
{0,1,2,3,4},
{5,6,7,8,9},
{10,11,12,13,14},
{15,16,17,18,19},
{20,21,22,23},
struct rotariesdef {
byte pin1;
byte pin2;
int ccwchar;
int cwchar;
volatile unsigned char state;
rotariesdef rotaries[NUMROTARIES] {
{0,1,24,25,0},
{2,3,26,27,0},
{4,5,28,29,0},
{6,7,30,31,0},
#define DIR_CCW 0x10
#define DIR_CW 0x20
#define R_START 0x0
#ifdef HALF_STEP
#define R_CCW_BEGIN 0x1
#define R_CW_BEGIN 0x2
#define R_START_M 0x3
#define R_CW_BEGIN_M 0x4
#define R_CCW_BEGIN_M 0x5
const unsigned char ttable[6][4] = {
// R_START (00)
{R_START_M, R_CW_BEGIN, R_CCW_BEGIN, R_START},
// R_CCW_BEGIN
{R_START_M | DIR_CCW, R_START, R_CCW_BEGIN, R_START},
// R_CW_BEGIN
{R_START_M | DIR_CW, R_CW_BEGIN, R_START, R_START},
// R_START_M (11)
{R_START_M, R_CCW_BEGIN_M, R_CW_BEGIN_M, R_START},
// R_CW_BEGIN_M
{R_START_M, R_START_M, R_CW_BEGIN_M, R_START | DIR_CW},
// R_CCW_BEGIN_M
{R_START_M, R_CCW_BEGIN_M, R_START_M, R_START | DIR_CCW},
#else
#define R_CW_FINAL 0x1
#define R_CW_NEXT 0x3
#define R_CCW_BEGIN 0x4
#define R_CCW_FINAL 0x5
#define R_CCW_NEXT 0x6
const unsigned char ttable[7][4] = {
// R_START
{R_START, R_CW_BEGIN, R_CCW_BEGIN, R_START},
// R_CW_FINAL
{R_CW_NEXT, R_START, R_CW_FINAL, R_START | DIR_CW},
// R_CW_BEGIN
{R_CW_NEXT, R_CW_BEGIN, R_START, R_START},
// R_CW_NEXT
{R_CW_NEXT, R_CW_BEGIN, R_CW_FINAL, R_START},
// R_CCW_BEGIN
{R_CCW_NEXT, R_START, R_CCW_BEGIN, R_START},
// R_CCW_FINAL
{R_CCW_NEXT, R_CCW_FINAL, R_START, R_START | DIR_CCW},
// R_CCW_NEXT
{R_CCW_NEXT, R_CCW_FINAL, R_CCW_BEGIN, R_START},
#endif
byte rowPins[NUMROWS] = {21,20,19,18,15};
byte colPins[NUMCOLS] = {14,16,10,9,8};
Keypad buttbx = Keypad( makeKeymap(buttons), rowPins, colPins, NUMROWS, NUMCOLS);
Joystick_ Joystick(JOYSTICK_DEFAULT_REPORT_ID,
JOYSTICK_TYPE_JOYSTICK, 32, 0,
false, false, false, false, false, false,
false, false, false, false, false);
Joystick.begin();
rotary_init();}
CheckAllEncoders();
CheckAllButtons();
void CheckAllButtons(void) {
if (buttbx.getKeys())
for (int i=0; i<LIST_MAX; i++)
if ( buttbx.key*.stateChanged ) *
    _ switch (buttbx.key*.kstate) { _
    _
    case PRESSED:_
    _
    case HOLD:_
    _ Joystick.setButton(buttbx.key.kchar, 1);
    case RELEASED:
    case IDLE:
    Joystick.setButton(buttbx.key.kchar, 0);
    void rotary_init() {
    for (int i=0;i<NUMROTARIES;i++) {
    pinMode(rotaries.pin1, INPUT);
    pinMode(rotaries.pin2, INPUT);_
    #ifdef ENABLE_PULLUPS*
    _ digitalWrite(rotaries*.pin1, HIGH);
    digitalWrite(rotaries.pin2, HIGH);
    #endif*
    }_
    unsigned char rotary_process(int _i) {
    unsigned char pinstate = (digitalRead(rotaries[i].pin2) << 1) | digitalRead(rotaries[i].pin1);
    rotaries[i].state = ttable[rotaries[i].state & 0xf][pinstate];
    return (rotaries[i].state & 0x30);*
    void CheckAllEncoders(void) {
    * for (int i=0;i<NUMROTARIES;i++) {_
    unsigned char result = rotary_process(i);
    if (result == DIR_CCW) {
    Joystick.setButton(rotaries_.ccwchar, 1); delay(50); Joystick.setButton(rotaries.ccwchar, 0);
    };_
    if (result == DIR_CW) {
    Joystick.setButton(rotaries_.cwchar, 1); delay(50); Joystick.setButton(rotaries.cwchar, 0);
    however , when I verify have some error , I already install the keypad and joystick from library . some how still got error for joystick portion .
    can anyone guide and help me on this .
    my error show below
    Arduino: 1.8.9 (Windows 10), Board: “Arduino/Genuino Uno”
    In file included from C:\Users\AST009000\Documents\Arduino\libraries\Keypad\src/Keypad.h:36:0,_
    from D:\Downloads\32-FUNCTION-BUTTON-BOX-master\32-FUNCTION-BUTTON-BOX-master\ARDUINO_BUTTON_BOXV2\ARDUINO_BUTTON_BOXV2.ino:9:
    C:\Users\AST009000\Documents\Arduino\libraries\Keypad\src/Key.h:41:21: error: ‘PRESSED’ redeclared as different kind of symbol
    typedef enum{ IDLE, PRESSED, HOLD, RELEASED } KeyState;
    _ ^
    In file included from D:\Downloads\32-FUNCTION-BUTTON-BOX-master\32-FUNCTION-BUTTON-BOX-master\ARDUINO_BUTTON_BOXV2\ARDUINO_BUTTON_BOXV2.ino:1:0:
    C:\Program Files (x86)\Arduino\libraries\Esplora\src/Esplora.h:73:15: note: previous declaration ‘const boolean PRESSED’
    const boolean PRESSED = LOW;
    C:\Users\AST009000\Documents\Arduino\libraries\Keypad\src/Key.h:41:36: error: ‘RELEASED’ redeclared as different kind of symbol
    _ ^
    C:\Program Files (x86)\Arduino\libraries\Esplora\src/Esplora.h:74:15: note: previous declaration ‘const boolean RELEASED’
    const boolean RELEASED = HIGH;
    *ARDUINO_BUTTON_BOXV2:97:1: error: 'Joystick’ does not name a type
    D:\Downloads\32-FUNCTION-BUTTON-BOX-master\32-FUNCTION-BUTTON-BOX-master\ARDUINO_BUTTON_BOXV2\ARDUINO_BUTTON_BOXV2.ino: In function ‘void setup()’:
    ARDUINO_BUTTON_BOXV2:103:11: error: expected unqualified-id before ‘.’ token
    * Joystick.begin();*
    D:\Downloads\32-FUNCTION-BUTTON-BOX-master\32-FUNCTION-BUTTON-BOX-master\ARDUINO_BUTTON_BOXV2\ARDUINO_BUTTON_BOXV2.ino: In function ‘void CheckAllButtons()’:
    ARDUINO_BUTTON_BOXV2:124:39: error: expected unqualified-id before ‘.’ token
    _ Joystick.setButton(buttbx.key*.kchar, 1);
    ARDUINO_BUTTON_BOXV2:127:21: error: duplicate case value
    case IDLE:
    ARDUINO_BUTTON_BOXV2:122:21: error: previously used here
    case PRESSED:
    ARDUINO_BUTTON_BOXV2:128:39: error: expected unqualified-id before ‘.’ token
    D:\Downloads\32-FUNCTION-BUTTON-BOX-master\32-FUNCTION-BUTTON-BOX-master\ARDUINO_BUTTON_BOXV2\ARDUINO_BUTTON_BOXV2.ino: In function ‘void CheckAllEncoders()’:
    ARDUINO_BUTTON_BOXV2:159:15: error: expected unqualified-id before ‘.’ token
    Joystick.setButton(rotaries.ccwchar, 1); delay(50); Joystick.setButton(rotaries.ccwchar, 0);
    ARDUINO_BUTTON_BOXV2:159:70: error: expected unqualified-id before ‘.’ token
    ARDUINO_BUTTON_BOXV2:162:15: error: expected unqualified-id before ‘.’ token
    Joystick.setButton(rotaries.cwchar, 1); delay(50); Joystick.setButton(rotaries.cwchar, 0);
    ARDUINO_BUTTON_BOXV2:162:69: error: expected unqualified-id before ‘.’ token
    exit status 1_
    ‘Joystick_’ does not name a type*
    “Show verbose output during compilation”
    option enabled in File → Preferences.
