Hello Everyone,
I have a sim7000A module and want to send a very large packet of data similar to the following below:
x:0.02333,y:0.33321,Z:9.8123,T:4:13:30:301,x:0.01333,y:0.23321,Z:9.8523,T:4:13:30:315, x:0.05333,y:0.13321,Z:9.8113,T:4:13:30:330....
I have tried 2 methods, but it seems that the maximum size is 1500 bytes. That comes out to be around 30 packets of data. If I change my code to 31 it gives me a 400 error. Every number under 30 works, so I am not sure what the maximum is. I want to send 100 or 150 packets if possible.
Code below:
//Update V3_ 23-FEB-2023
// ADXL345 Accelerometer, and a Depth sensor
#include <esp_now.h>
#include <WiFi.h>
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_ADXL345_U.h>
#include "RTClib.h"
RTC_DS3231 rtc;
Adafruit_ADXL345_Unified accel = Adafruit_ADXL345_Unified();
//Pins for depth sensors (4 sensors)
#define TRIG1 13 //Module pins Depth sensor_1
#define ECHO1 12
//Depth_sensor_2
#define TRIG2 14
#define ECHO2 26
//Depth_senosr_3me
#define TRIG3 33
#define ECHO3 32
//Depth_sensor_4
#define TRIG4 25 //35 on board
#define ECHO4 27 // 34 on board
//int distance_Measure1 = 0;
float distance_Measure1 = 0.0;
float distance_Measure2 = 0.0;
float distance_Measure3 = 0.0;
float distance_Measure4 = 0.0;
bool error;
float X_avg = 0.0;
float Y_avg = 0.0;
float Z_avg = 0.0;
//Time Variables
int previous_Sec = 0;
int Millis_Time = 0;
int C_millis = 0;
int P_millis = 0;
String time_now = "";
float temperatureF = 0.0;
//variables to keep track of the timing of 1 min for diferent packets to send
unsigned long start_time = 0;
unsigned long last_time = 0;
// REPLACE WITH YOUR RECEIVER MAC Address
//uint8_t broadcastAddress[] = {0x94, 0xB9, 0x7E, 0xE9, 0xBB, 0xAC};
//sim7000A Address = {0x4C, 0x75, 0x25, 0x67, 0x33, 0x14};
//simm7000G Address = {0x70, 0xB8, 0xF6, 0x06, 0xA5, 0xF8}
uint8_t broadcastAddress[] = {0x4C, 0x75, 0x25, 0x67, 0x33, 0x14};
// Structure to send data from ESP32 using ESPNOW
// Must match the receiver structure
typedef struct struct_message {
char depth1[10];
char depth2[10];
char depth3[10];
char depth4[10];
char accel_x[10];
char accel_y[10];
char accel_z[10];
char TTime[40];
char Temp[10];
} struct_message;
// Create a struct_message called myData
struct_message myData;
esp_now_peer_info_t peerInfo;
// callback when data is sent
void OnDataSent(const uint8_t *mac_addr, esp_now_send_status_t status) {
// Serial.print("\r\nLast Packet Send Status:\t");
//Serial.println(status == ESP_NOW_SEND_SUCCESS ? "Delivery Success" : "Delivery Fail");
rtc.begin();
//rtc.adjust(DateTime(__DATE__, __TIME__));
// rtc.adjust(DateTime(0, 0, 0, 16, 34, 00)); // Set the desired time here
initWifi(); // Function to initialize WiFi
initESPNOW(); // Funtcion to initialize ESPNOW communication between ESP32
init_depth_Sensor(); // Initialize depth sensor
init_Accl_Sensor(); // Initialize Accel sensor
accel.setDataRate(ADXL345_DATARATE_3200_HZ); // Set the data rate to 3200 Hz (maximum)
start_time = millis();
if (start_time - last_time >= 60 * 1000) // X * Seconds
// Serial.println("Combined: ");
//MeasureTime(); //Measure Time
Measure_Accleromter(); // Measure accel
Measure_Depth(); //Measure depth
sendEspNowData(); //function to send notification to other ESP32 (recieving ESP32)
last_time = start_time;
// Serial.println("Only: ");
distance_Measure2 = 0;
distance_Measure3 = 0;
distance_Measure4 = 0;
temperatureF = 0;
////////////////////////////////////////////INITILIZATION OF FUNCTIONS///////////////////////////
//Function to initialze WiFi
void initWifi() {
// Set device as a Wi-Fi Station
WiFi.mode(WIFI_STA);
//Function to initilaze ESPNOW communication
void initESPNOW() {
// Init ESP-NOW
if (esp_now_init() != ESP_OK) {
// Serial.println("Error initializing ESP-NOW");
return;
// Once ESPNow is successfully Init, we will register for Send CB to
// get the status of Trasnmitted packet
esp_now_register_send_cb(OnDataSent);
// Register peer
memcpy(peerInfo.peer_addr, broadcastAddress, 6);
peerInfo.channel = 0;
peerInfo.encrypt = false;
// Add peer
if (esp_now_add_peer(&peerInfo) != ESP_OK) {
//Serial.println("Failed to add peer");
return;
// Serial.println("ESPNOW initialize sucssfully");
// Function to initialize depth sensor
void init_depth_Sensor() {
pinMode(TRIG1, OUTPUT); // Initializing Trigger Output
pinMode(ECHO1, INPUT_PULLUP);
pinMode(TRIG2, OUTPUT); // Initializing Trigger Output and Echo Input
pinMode(ECHO2, INPUT_PULLUP);
pinMode(TRIG3, OUTPUT); // Initializing Trigger Output and Echo Input
pinMode(ECHO3, INPUT_PULLUP);
pinMode(TRIG4, OUTPUT); // Initializing Trigger Output and Echo Input
pinMode(ECHO4, INPUT_PULLUP);
void TCA9548A(uint8_t bus)
Wire.beginTransmission(0x70); // TCA9548A address is 0x70
Wire.write(1 << bus); // send byte to select bus
Wire.endTransmission();
// Serial.print(bus);
// Function to initialize Accelerometer sensor
void init_Accl_Sensor(void)
Wire.begin(); //start wire library for i2c
error = Wire.endTransmission();
if (error == 0) {
// Serial.print("TCA9548A found at address 0x70");
else {
Serial.println("No TCA9548A detected. Something went wrong!");
while (1);
//Initialize channel 1 to channel 6 if TCA9548A with ADXL345
for (int i = 1; i < 7; I++)
TCA9548A(i);
if (!accel.begin()) {
// Serial.println("No ADXL345 sensor detected.");
while (1);
Serial.print("ADXL345 sensor detected. : ");
Serial.print(i);
accel.setRange(ADXL345_RANGE_2_G);
displayRange();
//delay(10);
void displayRange(void)
Serial.print(" Range: +/- ");
switch (accel.getRange())
case ADXL345_RANGE_16_G:
Serial.print("16 ");
case ADXL345_RANGE_8_G:
Serial.print("8 ");
case ADXL345_RANGE_4_G:
Serial.print("4 ");
case ADXL345_RANGE_2_G:
Serial.print("2 ");
default:
Serial.print("?? ");
Serial.println(" g");
/////////////////////////////////////////////////FUNCTION TO MEASURE SENSORS DATA///////////////////////////////////////
void MeasureTime() {
DateTime now = rtc.now();
int hr = now.hour();
int mn = now.minute();
int sec = now.second();
int current_sec = now.second();
if (current_sec == previous_Sec)
C_millis = millis();
Millis_Time = ( C_millis - P_millis );
if (Millis_Time >= 999)
P_millis = C_millis;
Millis_Time = random(998, 999);
previous_Sec = current_sec;
Millis_Time = 14;
time_now = (String)hr + ":" + (String) mn + ":" + (String) sec + ":" + (String)Millis_Time;
// Serial.println("Time now: ");
//Serial.println(time_now);
// Serial.println();
float temperatureC = rtc.getTemperature();
temperatureF = (temperatureC * 9 / 5) + 32; // Convert Celsius to Fahrenheit
//Serial.print(" ");
// Serial.println(temperatureF);
//Serial.println();
// Function to measure depth
void Measure_Depth() {
//sensor_1 calculation
digitalWrite(TRIG1, LOW); // Set the trigger pin to low for 2uS
delayMicroseconds(2);
digitalWrite(TRIG1, HIGH); // Send a 10uS high to trigger ranging
delayMicroseconds(20);
digitalWrite(TRIG1, LOW); // Send pin low again
distance_Measure1 = pulseIn(ECHO1, HIGH, 26000); // Read in times pulse
distance_Measure1 = distance_Measure1 / 52; //Convert the pulse duration to distance
//delay(5);
//sensor_2 calculation
digitalWrite(TRIG2, LOW); // Set the trigger pin to low for 2uS
digitalWrite(TRIG2, HIGH); // Send a 10uS high to trigger ranging
digitalWrite(TRIG2, LOW); // Send pin low again
distance_Measure2 = pulseIn(ECHO2, HIGH, 26000); // Read in times pulse
distance_Measure2 = distance_Measure2 / 52; //Convert the pulse duration to distance
//delay(50);
//sensor_3 calculation
digitalWrite(TRIG3, LOW); // Set the trigger pin to low for 2uS
digitalWrite(TRIG3, HIGH); // Send a 10uS high to trigger ranging
digitalWrite(TRIG3, LOW); // Send pin low again
distance_Measure3 = pulseIn(ECHO3, HIGH, 26000); // Read in times pulse
distance_Measure3 = distance_Measure3 / 52; //Convert the pulse duration to distance
//delay(50);
//sensor_4 calculation
digitalWrite(TRIG4, LOW); // Set the trigger pin to low for 2uS
digitalWrite(TRIG4, HIGH); // Send a 10uS high to trigger ranging
digitalWrite(TRIG4, LOW); // Send pin low again
distance_Measure4 = pulseIn(ECHO4, HIGH, 26000); // Read in times pulse
distance_Measure4 = distance_Measure4 / 52; //Convert the pulse duration to distance
//delay(50);
//13.4 for Water
//52 or 58 for air
Serial.print("\n Distance (depth) by sensor_1: \n");
Serial.print(distance_Measure1);
Serial.println("cm");
Serial.print("\n Distance (depth) by sensor_2: \n");
Serial.print(distance_Measure2);
Serial.print("\n Distance (depth) by sensor_3: \n");
Serial.print(distance_Measure3);
Serial.print("\n Distance (depth) by sensor_4: \n");
Serial.print(distance_Measure4);
//delay(50);
// Function to measure Accelerometer
void Measure_Accleromter(void)
X_avg = 0.0;
Y_avg = 0.0;
Z_avg = 0.0;
for (int i = 1; i < 7; i++) {
TCA9548A(i);
sensors_event_t event;
accel.getEvent(&event);
X_avg += event.acceleration.x;
Y_avg += event.acceleration.y;
Z_avg += event.acceleration.z;
// Need to measure time here
// Function to send data using ESPNOW
void sendEspNowData() {
// Serial.println("SendESPNowData Function: ");
float accel_x = X_avg / 6 ;
float accel_y = Y_avg / 6 ;
float accel_z = Z_avg / 6 ;
//buffer for converting float into string
char depth1_string[8];
memset(depth1_string, 0, 8);
char depth2_string[8];
memset(depth2_string, 0, 8);
char depth3_string[8];
memset(depth3_string, 0, 8);
char depth4_string[8];
memset(depth4_string, 0, 8);
char accel_x_string[10];
memset(accel_x_string, 0, 10);
char accel_y_string[10];
memset(accel_y_string, 0, 10);
char accel_z_string[10];
memset(accel_z_string, 0, 10);
char temp_string[10];
memset(temp_string, 0, 10);
//Convert float into string
dtostrf(distance_Measure1, 6, 2, depth1_string);
dtostrf(distance_Measure2, 6, 2, depth2_string);
dtostrf(distance_Measure3, 6, 2, depth3_string);
dtostrf(distance_Measure4, 6, 2, depth4_string);
dtostrf(accel_x, 6, 5, accel_x_string);
dtostrf(accel_y, 6, 5, accel_y_string);
dtostrf(accel_z, 6, 5, accel_z_string);
dtostrf(temperatureF, 6, 2, temp_string);
char time_NOW[40];
time_now.toCharArray(time_NOW, 40);
// sprintf(time_NOW, "%c", time_now);
// Serial.println("time_NOW___");
// Serial.println(time_NOW);
strcpy(myData.depth1, depth1_string);
strcpy(myData.depth2, depth2_string);
strcpy(myData.depth3, depth3_string);
strcpy(myData.depth4, depth4_string);
strcpy(myData.accel_x, accel_x_string);
strcpy(myData.accel_y, accel_y_string);
strcpy(myData.accel_z, accel_z_string);
strcpy(myData.TTime, time_NOW);
strcpy(myData.Temp, temp_string);
// Serial.println("\n myData.depth_1 is: ");
// Serial.println(myData.depth1);
// Serial.println("\n myData.depth_2 is: ");
//Serial.println(myData.depth2);
// Serial.println("\n myData.depth_3 is: ");
// Serial.println(myData.depth3);
// Serial.println("\n myData.depth_4 is: ");
// Serial.println(myData.depth4);
// Serial.println("\n myData.accel_x is: ");
Serial.println(myData.accel_x);
//Serial.println("\n myData.accel_y is: ");
Serial.println(myData.accel_y);
//Serial.println("\n myData.accel_z is: ");
Serial.println(myData.accel_z);
//Serial.println("\n myData.TTime is: ");
Serial.println(myData.TTime);
// Serial.println("\n myData.Temp is: ");
//Serial.println(myData.Temp);
// Send message via ESP-NOW
esp_err_t result = esp_now_send(broadcastAddress, (uint8_t *) &myData, sizeof(myData));
if (result == ESP_OK) {
// Serial.println("Sent with success");
else {
Serial.println("Error sending the data");
//delay(50);
