Sim7000A sending Data to Server Guidance
When a Sim7000G (my receiver) is sending data to a server using HTTP protocol, it opens and closes the connection. During this sending procedure, I still have incoming data (my transmitter) that is being lost since the Sim7000G is in sending the last packet of around 1500 bytes (takes about 3 seconds). Is there a way to not lose the incoming data from the transmitter when the Sim7000G is sending the last packet to the server? My code is below:
//Update V3_ 23-FEB-2023
// ADXL345 Accelerometer, and a Depth sensor
#include <esp_now.h>
#include <WiFi.h>
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_ADXL345_U.h>
#include "RTClib.h"
RTC_DS3231 rtc;
Adafruit_ADXL345_Unified accel = Adafruit_ADXL345_Unified();
//Pins for depth sensors (4 sensors)
#define TRIG1 13 //Module pins Depth sensor_1
#define ECHO1 12
//Depth_sensor_2
#define TRIG2 14
#define ECHO2 26
//Depth_senosr_3me
#define TRIG3 33
#define ECHO3 32
//Depth_sensor_4
#define TRIG4 25 //35 on board
#define ECHO4 27 // 34 on board
//int distance_Measure1 = 0;
float distance_Measure1 = 0.0;
float distance_Measure2 = 0.0;
float distance_Measure3 = 0.0;
float distance_Measure4 = 0.0;
bool error;
float X_avg = 0.0;
float Y_avg = 0.0;
float Z_avg = 0.0;
//Time Variables
int previous_Sec = 0;
int Millis_Time = 0;
int C_millis = 0;
int P_millis = 0;
String time_now = "";
float temperatureF = 0.0;
//variables to keep track of the timing of 1 min for diferent packets to send
unsigned long start_time = 0;
unsigned long last_time = 0;
// REPLACE WITH YOUR RECEIVER MAC Address
//uint8_t broadcastAddress[] = {0x94, 0xB9, 0x7E, 0xE9, 0xBB, 0xAC};
//sim7000A Address  = {0x4C, 0x75, 0x25, 0x67, 0x33, 0x14};
//simm7000G Address = {0x70, 0xB8, 0xF6, 0x06, 0xA5, 0xF8}
uint8_t broadcastAddress[] = {0x4C, 0x75, 0x25, 0x67, 0x33, 0x14};
// Structure to send data from ESP32 using ESPNOW
// Must match the receiver structure
typedef struct struct_message {
  float depth1;
  float depth2;
  float depth3;
  float depth4;
  float accel_x;
  float accel_y;
  float accel_z;
  char TTime[15];
  float Temp;
} struct_message;
// Create a struct_message called myData
struct_message myData;
esp_now_peer_info_t peerInfo;
// callback when data is sent
void OnDataSent(const uint8_t *mac_addr, esp_now_send_status_t status) {
  // Serial.print("\r\nLast Packet Send Status:\t");
  //Serial.println(status == ESP_NOW_SEND_SUCCESS ? "Delivery Success" : "Delivery Fail");
  rtc.begin();
  //rtc.adjust(DateTime(__DATE__, __TIME__));
   // rtc.adjust(DateTime(0, 0, 0, 22, 25, 00));  // Set the desired time here
  initWifi();  // Function to initialize WiFi
  initESPNOW();  // Funtcion to initialize ESPNOW communication between ESP32
  init_depth_Sensor(); // Initialize depth sensor
  init_Accl_Sensor(); // Initialize Accel sensor
  accel.setDataRate(ADXL345_DATARATE_3200_HZ); // Set the data rate to 3200 Hz (maximum)
  start_time = millis();
  if (start_time - last_time >= 60 * 1000) //  X * Seconds
    // Serial.println("Combined: ");
    //MeasureTime(); //Measure Time
    Measure_Accleromter(); // Measure accel
    Measure_Depth(); //Measure depth
    sendEspNowData();  //function to send notification to other ESP32 (recieving ESP32)
    last_time = start_time;
    // Serial.println("Only: ");
    distance_Measure2 = 0;
    distance_Measure3 = 0;
    distance_Measure4 = 0;
    temperatureF = 0;
////////////////////////////////////////////INITILIZATION OF FUNCTIONS///////////////////////////
//Function to initialze WiFi
void initWifi() {
  // Set device as a Wi-Fi Station
  WiFi.mode(WIFI_STA);
//Function to initilaze ESPNOW communication
void initESPNOW() {
  // Init ESP-NOW
  if (esp_now_init() != ESP_OK) {
    //  Serial.println("Error initializing ESP-NOW");
    return;
  // Once ESPNow is successfully Init, we will register for Send CB to
  // get the status of Trasnmitted packet
  esp_now_register_send_cb(OnDataSent);
  // Register peer
  memcpy(peerInfo.peer_addr, broadcastAddress, 6);
  peerInfo.channel = 0;
  peerInfo.encrypt = false;
  // Add peer
  if (esp_now_add_peer(&peerInfo) != ESP_OK) {
    //Serial.println("Failed to add peer");
    return;
  // Serial.println("ESPNOW initialize sucssfully");
// Function to initialize depth sensor
void init_depth_Sensor() {
  pinMode(TRIG1, OUTPUT); // Initializing Trigger Output
  pinMode(ECHO1, INPUT_PULLUP);
  pinMode(TRIG2, OUTPUT); // Initializing Trigger Output and Echo Input
  pinMode(ECHO2, INPUT_PULLUP);
  pinMode(TRIG3, OUTPUT); // Initializing Trigger Output and Echo Input
  pinMode(ECHO3, INPUT_PULLUP);
  pinMode(TRIG4, OUTPUT); // Initializing Trigger Output and Echo Input
  pinMode(ECHO4, INPUT_PULLUP);
void TCA9548A(uint8_t bus)
  Wire.beginTransmission(0x70); // TCA9548A address is 0x70
  Wire.write(1 << bus);         // send byte to select bus
  Wire.endTransmission();
  // Serial.print(bus);
// Function to initialize Accelerometer sensor
void init_Accl_Sensor(void)
  Wire.begin(); //start wire library for i2c
  error = Wire.endTransmission();
  if (error == 0) {
    // Serial.print("TCA9548A found at address 0x70");
  else {
    Serial.println("No TCA9548A detected. Something went wrong!");
    while (1);
  //Initialize channel 1 to channel 6 if TCA9548A with ADXL345
  for (int i = 1; i < 7; I++)
    TCA9548A(i);
    if (!accel.begin()) {
      // Serial.println("No ADXL345 sensor detected.");
      while (1);
      Serial.print("ADXL345 sensor detected. : ");
      Serial.print(i);
    accel.setRange(ADXL345_RANGE_2_G);
    displayRange();
    //delay(10);
void displayRange(void)
  Serial.print("   Range: +/- ");
  switch (accel.getRange())
    case ADXL345_RANGE_16_G:
      Serial.print("16 ");
    case ADXL345_RANGE_8_G:
      Serial.print("8 ");
    case ADXL345_RANGE_4_G:
      Serial.print("4 ");
    case ADXL345_RANGE_2_G:
      Serial.print("2 ");
    default:
      Serial.print("?? ");
  Serial.println(" g");
/////////////////////////////////////////////////FUNCTION TO MEASURE SENSORS DATA///////////////////////////////////////
void MeasureTime() {
  DateTime now = rtc.now();
  int hr = now.hour();
  int mn = now.minute();
  int sec = now.second();
  int current_sec = now.second();
  if (current_sec == previous_Sec)
    C_millis = millis();
    Millis_Time = ( C_millis - P_millis );
    if (Millis_Time >= 999)
      P_millis = C_millis;
      Millis_Time = random(998, 999);
    previous_Sec = current_sec;
    Millis_Time = 14;
  time_now = (String)hr + ":" + (String) mn + ":" + (String) sec + ":" + (String)Millis_Time;
  //  Serial.println("Time now: ");
  //Serial.println(time_now);
  // Serial.println();
  float temperatureC = rtc.getTemperature();
  temperatureF = (temperatureC * 9 / 5) + 32; // Convert Celsius to Fahrenheit
  //Serial.print(" ");
  // Serial.println(temperatureF);
// Function to measure depth
void Measure_Depth() {
  //sensor_1 calculation
  digitalWrite(TRIG1, LOW); // Set the trigger pin to low for 2uS
  delayMicroseconds(2);
  digitalWrite(TRIG1, HIGH); // Send a 10uS high to trigger ranging
  delayMicroseconds(20);
  digitalWrite(TRIG1, LOW); // Send pin low again
  distance_Measure1 = pulseIn(ECHO1, HIGH, 26000); // Read in times pulse
  distance_Measure1 = distance_Measure1 / 52; //Convert the pulse duration to distance
  //delay(5);
  //sensor_2 calculation
  digitalWrite(TRIG2, LOW); // Set the trigger pin to low for 2uS
  digitalWrite(TRIG2, HIGH); // Send a 10uS high to trigger ranging
  digitalWrite(TRIG2, LOW); // Send pin low again
  distance_Measure2 = pulseIn(ECHO2, HIGH, 26000); // Read in times pulse
  distance_Measure2 = distance_Measure2 / 52; //Convert the pulse duration to distance
  //delay(50);
  //sensor_3 calculation
  digitalWrite(TRIG3, LOW); // Set the trigger pin to low for 2uS
  digitalWrite(TRIG3, HIGH); // Send a 10uS high to trigger ranging
  digitalWrite(TRIG3, LOW); // Send pin low again
  distance_Measure3 = pulseIn(ECHO3, HIGH, 26000); // Read in times pulse
  distance_Measure3 = distance_Measure3 / 52; //Convert the pulse duration to distance
  //delay(50);
  //sensor_4 calculation
  digitalWrite(TRIG4, LOW); // Set the trigger pin to low for 2uS
  digitalWrite(TRIG4, HIGH); // Send a 10uS high to trigger ranging
  digitalWrite(TRIG4, LOW); // Send pin low again
  distance_Measure4 = pulseIn(ECHO4, HIGH, 26000); // Read in times pulse
  distance_Measure4 = distance_Measure4 / 52; //Convert the pulse duration to distance
  //delay(50);
  //13.4 for Water
  //52 or 58 for air
    Serial.print("\n Distance (depth) by sensor_1:  \n");
    Serial.print(distance_Measure1);
    Serial.println("cm");
    Serial.print("\n Distance (depth) by sensor_2:  \n");
    Serial.print(distance_Measure2);
    Serial.print("\n Distance (depth) by sensor_3:  \n");
    Serial.print(distance_Measure3);
    Serial.print("\n Distance (depth) by sensor_4:  \n");
    Serial.print(distance_Measure4);
  //delay(50);
// Function to measure Accelerometer
void Measure_Accleromter(void)
  X_avg = 0.0;
  Y_avg = 0.0;
  Z_avg = 0.0;
  for (int i = 1; i < 7; i++) {
    TCA9548A(i);
    sensors_event_t event;
    accel.getEvent(&event);
    X_avg += event.acceleration.x;
    Y_avg += event.acceleration.y;
    Z_avg += event.acceleration.z;
  // Need to measure time here
// Function to send data using ESPNOW
void sendEspNowData() {
  // Serial.println("SendESPNowData Function: ");
  float accel_x = X_avg / 6 ;
  float accel_y = Y_avg / 6 ;
  float accel_z = Z_avg / 6 ;
  //buffer for converting float into string
  //  char depth1_string[8];
  //  memset(depth1_string, 0, 8);
  //  char depth2_string[8];
  //  memset(depth2_string, 0, 8);
  //  char depth3_string[8];
  //  memset(depth3_string, 0, 8);
  //  char depth4_string[8];
  //  memset(depth4_string, 0, 8);
  //  char accel_x_string[10];
  //  memset(accel_x_string, 0, 10);
  //  char accel_y_string[10];
  //  memset(accel_y_string, 0, 10);
  //  char accel_z_string[10];
  //  memset(accel_z_string, 0, 10);
  //  char temp_string[10];
  //  memset(temp_string, 0, 10);
  //Convert float into string
  //  dtostrf(distance_Measure1, 6, 2, depth1_string);
  //  dtostrf(distance_Measure2, 6, 2, depth2_string);
  //  dtostrf(distance_Measure3, 6, 2, depth3_string);
  //  dtostrf(distance_Measure4, 6, 2, depth4_string);
  //  dtostrf(accel_x, 6, 5, accel_x_string);
  //  dtostrf(accel_y, 6, 5, accel_y_string);
  //  dtostrf(accel_z, 6, 5, accel_z_string);
  //  dtostrf(temperatureF, 6, 2, temp_string);
  char time_NOW[15];
  time_now.toCharArray(time_NOW, 15);
  // sprintf(time_NOW, "%c", time_now);
  // Serial.println("time_NOW___");
  // Serial.println(time_NOW);
  myData.depth1=distance_Measure1;
  myData.depth2=distance_Measure2;
  myData.depth3=distance_Measure3;
  myData.depth4=distance_Measure4;
  myData.accel_x=accel_x;
  myData.accel_y=accel_y;
  myData.accel_z=accel_z;
  myData.Temp=temperatureF;
  strcpy(myData.TTime, time_NOW);
  // Serial.println("\n myData.depth_1 is: ");
  // Serial.println(myData.depth1);
  // Serial.println("\n myData.depth_2 is: ");
 // Serial.println(myData.depth2);
  // Serial.println("\n myData.depth_3 is: ");
  // Serial.println(myData.depth3);
  // Serial.println("\n myData.depth_4 is: ");
  // Serial.println(myData.depth4);
  // Serial.println("\n myData.accel_x is: ");
  Serial.println(myData.accel_x);
  //Serial.println("\n myData.accel_y is: ");
  Serial.println(myData.accel_y);
  //Serial.println("\n myData.accel_z is: ");
  Serial.println(myData.accel_z);
  //Serial.println("\n myData.TTime is: ");
  Serial.println(myData.TTime);
  // Serial.println("\n myData.Temp is: ");
  //Serial.println(myData.Temp);
  // Send message via ESP-NOW
  esp_err_t result = esp_now_send(broadcastAddress, (uint8_t *) &myData, sizeof(myData));
  if (result == ESP_OK) {
  //  Serial.println("Sent with success");
else {
  Serial.println("Error sending the data");
  //delay(50);
